Old 05-08-2007, 01:29 PM   #1
jimmydean
jimmydean's Avatar
Busted axle shaft removal on a Dana 44?
I will pull the diff cover this weekend and see what the deal is. But the axle shaft busted on the driver side and the PO pulled the shaft out, but left the broken piece.
I read last night that if there is no locker, then a coat hanger to push it out, or a shop vac to suck it out. I have a smaller shop vac, so I don't think it will have the juice to get the chunk out.
Anyone else have any tips or tricks without pulling the whole axle?
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-08-2007, 01:50 PM   #2
kwmech
Re: Busted axle shaft removal on a Dana 44?
A lot depends on where and how the axle broke--spline twist?---, and as you already know what type of locker the diff may have or not have.
Old 05-08-2007, 02:08 PM   #3
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
If its not stuck maybe a large hd magnet tool will pull it out OR you could remove the axle on the other side and drive it out with a long rod, if its just spidrer gears w/no locker.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 05-08-2007, 07:03 PM   #4
jimmydean
jimmydean's Avatar
I have no idea what's in there because I just bought the truck and drive it home. The axle shaft was laying in the bed and it looks like it broke just shy of the splines, but I'm not 100% sure how long the complete shaft is.
I will get it on stands and pull the cover this weekend, I just wanted to get an idea of what I might be in for. Did any '71 come with something in the front stock?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-08-2007, 07:18 PM   #5
1969k10stepside
What do you mean,posi?Locker?
I have seen a few K20s that had 4:56s with factory lockers.There would/should be a decal for the lockers in the cab...IIRC.I dont know if they were listed in glovebox...
1969k10stepside is offline   Reply With Quote
Old 05-08-2007, 10:15 PM   #6
msgross
msgross's Avatar
jack up te other side and take the wheel off the damaged side, try to get the angle of the axle as steep as possible...???
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-13-2007, 08:29 PM   #7
abebummy26
abebummy26's Avatar
I had to make a slide hammer to pull one out of a 61 cj5 on a Dana 44 rear but it was not broken just stubborn actually it was a PITA took a week to figure it out and make it and that was working on it 2 1/2 hours a day that was a beech hope it goes better for you.
abebummy26 is offline   Reply With Quote
Old 06-08-2007, 08:40 AM   #8
msgross
msgross's Avatar
is it fixed?
The Garage:
