Old 05-08-2007, 02:46 PM   #1
jorgensensc
jorgensensc's Avatar
Changing lug pattern?
Has anyone figured out a good way to change the front lug pattern from 5 x 5 to 5 x 4 3/4? I have the 1" rotors now, and I may have found a rotor that will work, but I'm not sure yet!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-08-2007, 03:44 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Changing lug pattern?
na i was trying to go from 5 lug to 6 and cant find anything either.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-08-2007, 03:58 PM   #3
jorgensensc
5 lug to 6 lug is merely a call away for you to CPP. I know because I thought about going that route first (my rear is still 6 lug)
Shawn
Old 05-08-2007, 04:13 PM   #4
Srubydo1986
The Crazy Machanic
ok im dumb What does cpp mean.
newest additions
Old 05-08-2007, 04:21 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Why do you want to change for 5 on 5 to 5 on 4 3/4?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-08-2007, 04:24 PM   #6
ocbaud
Garage Queen Material
i'm assuming so that he has a different selection of aftermarket wheels
ocbaud is offline   Reply With Quote
Old 05-08-2007, 04:49 PM   #7
jorgensensc
CPP = Classic Performance Parts THey have specialty rotors available for 5 lug to 6 lug applications.
Long story short, I have a 73+ crossmember on my 68. 5 x 5 lug pattern. I have a 6 lug rear. i have a set of 5 x 4 3/4 steel wheels off of my Bel Air (went aftermarket on Bel Air) I want to paint them red and run Spider Caps, (which only come in 5 x 4 3/4 and 5 x 4 1/2 lug patterns) So I need to get a set of rotors for the front that will be 5 x 4 3/4. Sound crazy enough?
