Old 05-08-2007, 06:16 PM   #1
72highlander
Sophomore Member
72highlander's Avatar
Install for sport mirrors
my truck had the gigantic below eyeline mirrors and didn't quite fit the theme of my truck, so i ditched them and bought sport mirrors. can anyone tell me how far back and how centered the bolts should be for me to drill them in the right spot? i appreciate it.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 05-08-2007, 06:43 PM   #2
john
member #16
john's Avatar
Re: Install for sport mirrors
look here
john is offline   Reply With Quote
Old 05-08-2007, 07:06 PM   #3
northerngmc
northerngmc's Avatar
Did you purchase GM or reproduction mirrors?
Just curious as TexasC10 and myself have both installed reproduction sport mirrors and have both found that the passenger side mirror will not adjust into place so it can be seen.
I have installed mine according to the instructions with the right side further back. I would suggest figuring out where they should go, then have someone hold the mirror and see if you can adjust the right side one before drilling holes.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-08-2007, 07:28 PM   #4
72highlander
Sophomore Member
thanks for the heads up, they are repro's, i got them against my better judgement, hope they work out, i will do as you said and if they don't work i'll buy some from gm. everything else i have is nos, don't know why i cheesed out on these.
Old 05-08-2007, 11:19 PM   #5
centsless
sufficiently talented fool
centsless's Avatar
I bought mine from the local GM dealer and love them. Mine adjusted fine, but the bottom corner of the right mirror is close to the base.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
