Old 05-08-2007, 06:53 PM   #1
chevyjmm6796
2 piece driveshaft
i can't seem to keep a support bearing in my truck for longer than about 1000 miles the p.o. had replaced the motor and trans mounts to correct problem but didnt. i found the spring bushings bad and have replaced all!! has anybody else had this problem, and fixed it??? 72 c-10 lowered2'' front, 4'' rear, leaf spring rear . please help!!
chevyjmm6796 is offline   Reply With Quote
Old 05-08-2007, 07:11 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: 2 piece driveshaft
Do you have an adjustable panhard bar? I lowered my truck 5" and the rearend was pushed off to one side as a result. I went through 4 center support bearings as a result. I've since switched to a one piece.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-08-2007, 07:26 PM   #3
sierragrande71
sierragrande71's Avatar
Hey dave2953 was it difficult to go to a 1 piece? I wondering this because I have a two piece in my '69 swb. Mine's a factory four speed does that matter any? I would like to eventually gone to the single piece driverline.
sierragrande71 is offline   Reply With Quote
Old 05-08-2007, 08:51 PM   #4
dave2953
dave2953's Avatar
No, just a little spendy (for me anyway) I actually found my one piece in the scrap pile at my local exhaust shop. I had it cut down at a driveline shop and it was about $130 for everything. I did have cut the pillow block out, but that was the only clearance issue I had. I don't think it matters that you have a four speed. Let me know if you have any other questions.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 05-08-2007, 08:52 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Have you had the DS balanced?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 05-08-2007, 09:14 PM   #6
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
Hmmmm.... My support bushing is going out, but because of old age.....I hope. All my support crossmember where the trailing arms connect (is that what its called?) is a little rusted. I would like to find a replacement, possibly a tubular one if available. Perhaps that one-piece driveshaft thing could be a path also. Do you know what kind of driveshaft it was?
I would def. look into a panhard bar if I were you, I have airsprings all the way around, so your drop would probably throw your rear end off like mine did.
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 05-08-2007, 09:19 PM   #7
ntroach454
ntroach454's Avatar
I was just pokin around under my suburban and noticed that my center support is worn out. How hard is it to replace? Thanks Nick
BIG PLANS, little money!
ntroach454 is offline   Reply With Quote
Old 05-08-2007, 09:59 PM   #8
dave2953
dave2953's Avatar
They aren't too bad to replace. Every time I've replaced one I took the new bearing and DS to a driveline shop and had it pressed on and u-joints installed. I've heard of people beating the bearing off with a hammer, but I didn't ever try that.
RocketChevy56: I'm not exactly sure what the application was. I think it was a Chevy truck, but I'm not certain.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 05-09-2007, 03:44 PM   #9
hyarbour
The one in my 71 GMC was simple. All I had to do was disconnect the the ends of the drive shaft from the tranny and dif, then pull the two apart from the bearing. Mine uses the bearing with the single tab, but of heard of the other type. Are those ones pressed to the drive shafts?
hyarbour is offline   Reply With Quote
