Old 05-08-2007, 06:58 PM   #1
WORNBRAKES
Question PIC request
Coud someone please post a pic of the steering arm on a K5? I would like to see one from a 69/70 and also a 71/72. I think that mine may have issues.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 05-08-2007, 07:12 PM   #2
1969k10stepside
Re: PIC request
The old axles with closed knuckles used different ones..thats why you cant (or atleast its hard to) get a raised steering arm for the ones with closed knuckles.
Here is some old pics of the one for my 71...its a raised steering arm though so it may not help...
Some pics where the steering looks funky is because it was lowered back to stock height so I could dissassemble the truck but the lifted steering arm stayed on...and then some pics are after it was lifted back up...
1969k10stepside is offline   Reply With Quote
Old 05-10-2007, 09:15 AM   #3
WORNBRAKES
Re: PIC request
Thanks Dustin. Does any one have a pic of a factory steering arm?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 05-10-2007, 09:51 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: PIC request
I can get you a pic of the steering arm on my 69 K20 that has a closed knuckle Dana 44.
I put a 1978 3/4 ton Dana 44 into my 70 K5 and I think I have the 78's stock steering arm laying around - would a picture of it also help you?
When i bought my 70 K5 the stock steering arm was already replaced with a raised steering arm.
The steering arm from the closed knuckle Dana 44 in my 69 K20 is of course totally different from the steering arm used on the open knuckle axles.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-10-2007, 02:02 PM   #5
WORNBRAKES
Re: PIC request
I would like to see pics of the 78 stock arm if you can Yukon. I am using an open knuckle. I am going to get a pic of mine this evening and post it as well. I am thinking that my arm is either incorrect or has issues.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 05-10-2007, 03:11 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: PIC request
I'll shot a pic of it tonight - I'm pretty sure I know where I put it (and that is a miracle if you've seen my shop!!)
Old 05-10-2007, 08:13 PM   #7
WORNBRAKES
Re: PIC request
This is what I have on the Blazer. It is an open knuckle 44.
I think that it has issues. I also bounce around and have a lot of play while driving.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 05-10-2007, 09:48 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: PIC request
Here's the stock one off of the 78 3/4 ton Dana 44 - you can have it if you need it.
Old 05-10-2007, 11:07 PM   #9
WORNBRAKES
Re: PIC request
Yours appears to be the same as mine. Do you agree? Looking at your 3rd picture and mine, they seem to have the same angle. I appreciate your offer but this may not be my problem. I will have to troubleshoot some more when I get a chance. If it comes up that I need it, I am sure I have something I can trade for it. Thanks again for the pictures.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 05-11-2007, 06:59 AM   #10
jaros44sr
jaros44sr's Avatar
Re: PIC request
Mine is a good 4-6 inches away from the axle tube. Don't know what the PO did, but it does have a 4" lift. Springs and blocks. The steering box and the steering arm are on a level plan. If you need pics lmk... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-11-2007, 09:15 AM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: PIC request
Yep, yours appears to be a stock steering arm. Can't imagine these actually having a wear issue so I agree your problem is probably something else.
Old 05-13-2007, 01:58 AM   #12
69TowRig
Re: PIC request
I bet yours has the same problem that mine used to. I think an accumulation of alignments over the years (or one bad one) caused the drag link to get too far elongated. When I bought it my Blazer would turn tighter in one direction than the other, the problem was that the steering box was not centered when the front wheels were. I had to screw in the adjuster on the drag link quite a few turns to get that part straight, then reset the steering wheel.
I noticed that there are a ton of thread showing on your drag link ends and this is what tipped me off to that. Tell me if I am crazy later. I am betting that when your wheels are straight that your pitman arm is not perpendicular to the frame, from the looks of it I bet it points somewhat forward towards the corner of the truck.
I realized what the problem was with mine when I converted it to power steering. The manual box had quite a bit of wear on it and had ~ 5-6" of slop in the steering wheel alone. Quite a scary drive!
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 05-13-2007, 02:00 PM   #13
WORNBRAKES
Re: PIC request
Thanks Towrig. I will take a look at that once I get a chance. I threw my lower back out last week so I am not getting around very easy. When I get it fixed, I will let you all know what I found.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
