Old 05-08-2007, 11:40 PM   #1
cstm68
cstm68's Avatar
one quick question.
does anyone have the dementions for the rear u bolts.
from inside to inside, the hight, and the diameter of the bolt
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 05-09-2007, 10:44 PM   #2
cstm68
cstm68's Avatar
Re: one quick question.
ttt
Old 05-10-2007, 05:16 AM   #3
JimKshortstep4x4
Is the u-bolt on a 2 WD or 4 WD?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-10-2007, 10:07 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If you are looking for longer or blocks here is a site.
http://www.stockcarproducts.com/trkarm1.htm
sneakysnake is offline   Reply With Quote
Old 05-10-2007, 10:19 AM   #5
kwmech
coil spring or leaf spring
Old 05-10-2007, 12:38 PM   #6
cstm68
cstm68's Avatar
coil spring 2wd
Old 05-10-2007, 01:17 PM   #7
nvrforgotten52
nvrforgotten52's Avatar
its a 3/4 inch stock... and if you know the width of the axle housing tube than you know the width from inside to inside...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 05-10-2007, 03:13 PM   #8
sneakysnake
Because of the diagonal mount the "Ubolts" are just a little wider than the axle tubes but I dont remember the exact measurment.
