Old 05-09-2007, 01:10 PM   #1
1lowdiesel
1lowdiesel's Avatar
700r4 behind my 250...please help me do it.
ok i've looked and looked and can't find anything about putting an auto behind my 6.i know people have done it. but i've even looked on inliners.org and even there i can't find chit. i just recently i put a small block in my 72 but now i'm reconsidering due to rising gas prices seeing how this will be my daily. someone please help point me in the right direction.
thanks kyle
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 05-09-2007, 02:45 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: 700r4 behind 250
Shouldn't be any different than having a manual tranny in there. The bellhousing should bolt right up.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-09-2007, 02:50 PM   #3
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Why don't you try to find a 4.3 v6 with a 700r4 and put it in your truck.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 05-09-2007, 02:50 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Shouldn't be any different than bolting it to a 350. As long as you get that thing tuned right, you should be getting some killer gas mileage.
Not to mention, that 3.06 first gear will get you off the line really well.
Pyrotechnic is offline   Reply With Quote
Old 05-09-2007, 02:51 PM   #5
1lowdiesel
1lowdiesel's Avatar
the 6cyl that i took out ran like a top. and yea the fuel mileage is what i'm after.
xtremediesel.com
Old 05-09-2007, 03:41 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
hooking up the TV cable will probably be a real PITA, and it is crutial to letting the tranny live for more than a year.
IMO, a stock, well tuned 350 will probably do about the same MPG wise. There's a few ppl who get lucky and claim 25 MPG or something crazy... but moving your rig through the aire kills the MPG regardless of what you have pushing it. You'll probably get better MPG rewards by getting the carb dialed in perfect, and learning to drive like a little old lady.
Old 05-09-2007, 04:09 PM   #7
bagged91
Out draggin'
bagged91's Avatar
Instead of the 700R4 swap, you could also swap over either a 200R4 which is the same length as a TH350shortshaft(what our trucks take) or talk to NitroMike... He is running an I6 wtih a T-5 tranny behind it. He said he likes it a lot...
A 307 is often underrated, but they do get EXCLELLENT gas milage... That is another option to consider...
L8R - Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 05-09-2007, 04:26 PM   #8
faribran
the suggestion of the 4.3 sounds like the avenue i would take.... i have never been able to get any gas mileage from the inline 250.
faribran is offline   Reply With Quote
Old 05-09-2007, 04:27 PM   #9
1lowdiesel
1lowdiesel's Avatar
little old lady...yea thats not gonna happen unless i run the 6.the thing is i just put a cam,carb,intake,rockers,lifters,and headers on it so.. at least i'll have a nice motor for my dad's.
hmmm, forgot about the tv cable, i'm sure i can rig something up though.
yea joe i thought about the t-5 but i'd rather have the auto. not to mention i already have 2 700r4's and a th350.
xtremediesel.com
Old 05-09-2007, 04:28 PM   #10
1lowdiesel
1lowdiesel's Avatar
whats never?
xtremediesel.com
Old 05-09-2007, 04:33 PM   #11
nvrforgotten52
nvrforgotten52's Avatar
im sure its possible to rig up a tv cable... it just may be a pain cuz the carb linkage is like sidways compared to a normal 4bbl on a small block
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 05-09-2007, 06:08 PM   #12
onetonk5
Cereal Killer
onetonk5's Avatar
Just a fwiw TCI just came out with a new valve body for a 700r4 that makes TV cable adjustment much less critical. Its part # 376020 if your interested. I just so happened to recieve mine yesterday.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 05-09-2007, 06:14 PM   #13
NitroMike
Active Member
NitroMike's Avatar
I do love my Tremec .64 high gear 5 speed behind my 250. Got 20.5 MPG going to and from jc's. And shifting is still fun when you don't have to do it every day. If I drove this truck everyday it would have a 700r4.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 05-11-2007, 10:24 AM   #14
1lowdiesel
1lowdiesel's Avatar
hey what about the flywheel/ can i use the small block one?
xtremediesel.com
