Old 05-09-2007, 04:51 PM   #1
gregbr
Senoir Member
gregbr's Avatar
WHo has vintage air??
I'm starting to install mine on a non a/c cab. After reading the instructions and contacting the tech support....the system using the factory heater controls does not have temp control. It appears to be wide open heat or a/c with no temperature control like the old heater had. Is this correct and is it a big problem?? I see where you can get a different inside unit and use the factory a/c controls and it will control the temp using a cable controlled heater valve instead of the vacuum open/closed valve that I have. According the tech support these are 2 different under dash units. Of course the dealer I used did not tell me any of this. Any advice..........Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 05-09-2007, 05:29 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: WHo has vintage air??
My first system I installed is like what you now have. You are right in that all you will have is heat or air and fan speed, no temp control. My second system I installed uses factory A/C controls and I like it better. What you have will work but you will find yourself cutting it on and off a lot on days where the outside temp is not very hot or very cold. If it was me I would spend the money to send what you have back and get the other system. Of course you are also going to have to add A/C controls but I think it's worth it in the long run. If I drove my truck more I would probably swap it to the factory control type system.
see ten is offline   Reply With Quote
Old 05-09-2007, 07:33 PM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
My Vintage Air system has a temperature control mounted on the underdash unit itself. It is a dial control that you have to reach under the glove box to get at. I have it set at max (cold) and have basically never had to adjust it. The way I adjust the temperature inside the cab is with the fan speed. I only use the A/C only when it is unbearable and use the windows and floor vents the rest of the time. To make a long story short, it hasn't been a problem for me.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 05-09-2007, 09:50 PM   #4
sleepyboy
'69 Step
sleepyboy is offline   Reply With Quote
Old 05-09-2007, 11:48 PM   #5
Blue85
Oilfield Trash
Blue85's Avatar
Mine has full heat and a/c temp adjustment, my kit was the for a factory a/c truck using factory contols.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 05-09-2007, 11:53 PM   #6
chevdanbarnett
chevdanbarnett's Avatar
new to these to but looking to go these way but i dont have air what about just heat and maybe air later in life
chevdanbarnett is offline   Reply With Quote
