Old 05-09-2007, 10:52 PM   #1
rauto13
saving one more
rauto13's Avatar
please id this rear axle
Just bought a 69 short wide and it has this rear axle. I have no idea what it is. It is a six lug rear axle. Anyone know what this rear axle is?
Thanks for the help.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 05-09-2007, 10:56 PM   #2
1969k10stepside
Re: please id this rear axle
Eaton....I think thats it..Maybe,I don't know the Eaton axles that good
1969k10stepside is offline   Reply With Quote
Old 05-09-2007, 11:35 PM   #3
eedgell
It's the air up here
eedgell's Avatar
Eaton
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-09-2007, 11:44 PM   #4
1970bowtie
1970bowtie's Avatar
you know how much we all like pics, how about some of the entire truck
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 05-10-2007, 12:44 AM   #5
Troy-Built
I quess there is a first time for everything but I have never seen a six lug Eaton. All of them I have seen were 8 lug and had bolt in axles at the outside hub. Get a picture of the front of the housing. Also the track bar shouldn't look like that.
69 Chevelle SS 375/396 TKO 600
71 Suburban 3/4 4x4 402 5-speed (project)
68 chevy C10 shortbed 327 5-speed (project)
72 Blazer 4x4 400 4-speed (wifes project)
Numerous 67-72 parts trucks
Troy-Built is offline   Reply With Quote
Old 05-10-2007, 01:09 AM   #6
RicksTrucks
RicksTrucks's Avatar
There should be numbers to the right of the pumpkin that would help
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 05-10-2007, 06:37 AM   #7
Blazer1970
Blazer1970's Avatar
It could be an older corporate axle. Similar in design to the HO52/HO72 but used in half ton applications. I believe they called it an HO33.
Blazer1970 is offline   Reply With Quote
Old 05-10-2007, 06:54 AM   #8
jkeady
jkeady's Avatar
I think Blazer1970 is right. I hate passing on second hand info, but have been told that a semi-float 6-lug with small tubes is the HO33 that was used in half-tons.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 05-10-2007, 09:45 AM   #9
rauto13
saving one more
rauto13's Avatar
pics of front of axle and one of the truck as found and purchased. I have a long way to go.
I am not seeing any numbers to the right of the carrier, should these be on the right axle tube?
Again thanks for the help.
Old 05-10-2007, 10:23 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
The code is stamped on the passenger side tube of the rear end housing. The first picture shows the area of the housing where the code is stamped and the second picture is of the code number itself. When You have the code just use the first two or three letters ('67-'69 have two letters & '70-'72 have three) and look it up here in the axle codes section.
http://www.americanclassic.com/paint.htm
It doesn't tell you who made it though.
The letters TDE on this one tells me it is a 307:1 - 1/2 ton assembly
LockDoc
Leon
Old 05-10-2007, 10:32 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
never seen that in a 67-72 1/2 ton.
Old 05-10-2007, 10:57 AM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
Ive never seen one like that in a 67-72 either. But my 1955 1/2 ton truck had one like that. So it must be a older axle like Blazer1970 said.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 05-10-2007, 11:25 AM   #13
rauto13
saving one more
rauto13's Avatar
The mount for the panhard bar is right where your photo shows where the code is located. I looked again and do not see a code stamped in this area.
I am at a loss here....
Old 05-10-2007, 11:29 AM   #14
rauto13
saving one more
rauto13's Avatar
story of my life, I am thinking of changing my nick to "I ain't seen nothing like that before"
Thanks again.
Old 05-10-2007, 10:06 PM   #15
rauto13
saving one more
rauto13's Avatar
anyone else have an idea what this rear axle is?
Old 05-11-2007, 10:21 AM   #16
Aarons72s
Id say it is what evryone says, the ho33. But I bet it came out of a 60-62? 1/2 ton. They had the same suspension as ours so it is possible to use the axle out of one. I believe 62 was the last year, please correct me if I am wrong. I think also a 67-72 with a ho52 that has coils might be able to supply you with a new panhard bar since yours is messed up. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 05-11-2007, 10:33 AM   #17
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
it strongly resembles the axle that was under a 61 1/2 ton apache short step I used to have.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
