Old 05-10-2007, 01:13 AM   #1
oldcarsown88
Question Max Lift?
whats the max lift i could put on a 4X4 gmc jimmy with out having to drop the transfer case?? i know id have to extend brakelines, linkage exc exc.
thanks!!
oldcarsown88 is offline   Reply With Quote
Old 05-11-2007, 01:04 AM   #2
oldcarsown88
Re: Max Lift?
no one knows??? common, i dont wanna have a wicked drive shaft angle
Old 05-11-2007, 10:02 AM   #3
Critter
Future TOTM Winner
Critter's Avatar
Re: Max Lift?
4 inch is a safe bet. By the time you get to 6 inch you usually have to lengthen the driveshafts or drop the trans case or something to help your driveshafts. If you are only on the street and you are just going for looks, then I don't think the driveshaft angel itself will be a problem with a 6in, but the length will. If your are hard core into off roading it will be a different story.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-11-2007, 10:14 AM   #4
Southedisto
River life......
Southedisto's Avatar
Re: Max Lift?
I have a four inch lift with the transfer case dropped 3/8" and I have no problems at all.
Southedisto is offline   Reply With Quote
Old 05-11-2007, 11:04 AM   #5
Critter
Future TOTM Winner
Critter's Avatar
Re: Max Lift?
Some more info here:
http://67-72chevytrucks.com/vboard/s...d.php?t=238974
Old 05-14-2007, 06:41 AM   #6
vtblazer
vtblazer's Avatar
Re: Max Lift?
thanks!!
Pretty much, all you want but you'll need double cardon joints on the drive shafts to do it.
vtblazer is offline   Reply With Quote
