05-10-2007, 04:16 AM | #1 |
front end brakes
I have a 79 1/2 ton that swerves to the right when I apply brakes, can anyone tell me why? I have installed new brakes,calipers,booster,master cylinder, prop. valve. wondering if it could be the left brake line not getting enough fluid??
05-10-2007, 04:22 AM | #2 |
Designated A-hole!
Re: front end brakes
First thing to do is a good bleed on the brakes.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-10-2007, 04:27 AM | #3 |
05-10-2007, 04:28 AM | #4 |
05-10-2007, 06:23 AM | #5 |
Designated A-hole!
Sounds like you need to invest in new hoses. If that doesn't do it I don't have a clue.
05-10-2007, 07:00 AM | #6 |
The One And Only !!!
I agree with krue on the hoses, Sounds like the right one is collapsing internally restricting fluid flow under pressure.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
05-10-2007, 08:25 AM | #7 |
Hoses will do exactly what you've described once one has swollen internally.
05-10-2007, 09:48 AM | #8 |
Robert Olson Transport
id still bleed the brakes good after installing the hoses and do both so you know both are good.. other thing is to make sure tire pressure is same and good in the tires and that all tires are the same size
05-10-2007, 01:06 PM | #9 |
Thanks for the info, ya'll so helpful, will jump on the hose project here pretty quick. This site ROCKS, beats going to local shops to ask and then get @!@#$% around!!! know what I mean.
05-10-2007, 02:55 PM | #10 |
Cruzzzn' Vet
Yo Bro how you doing , checked out my 83 shop manual for brakes and it gave these things to check:
Restricted brake fluid passage or sticking wheel cylinder piston. Air in system. Sticking caliper pistons. Sticking wheel cylinder. Glazed brake linings. Sounds like what everybody else has been saying, brake lines or air in the system In Visalia huh, glad to see more locals on the board 75 Silverstep is out of Tulare. John |
05-10-2007, 03:08 PM | #11 |
OL BLUU
If the truck is pulling to the right... your LEFT brake hose is more likely collapsing internally=replace. If you have the extra money... replace the the right side at the same time; you'll be doing it soon.
Anthony |
05-10-2007, 09:21 PM | #12 |
67 Chevy Stepside
get new hose's on both side
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
