Interior Dome and Courtesy Lights
Here is the situation. I have door pin switches that are not attached to anything and I have a light under the center of the dash that turns on when turning the light switch all the way to the left and I had wires coming out of the back of my headliner for the dome light. I installed the dome light that I had at the hole in the back of the headliner. Now I am trying to figure out how to hook it all up so that the lights will turn on when the doors open or when the light switch is turned to the left. I made this schmatic. Do you guys think this will work? I am not a wiring guru, but I am trying to think it through before attempting the rest of the wiring. I am also doing an dual electric fan project which I will post a schematic of when I know it works!
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop. |
K5Camper
![]() Join Date: Mar 2004
Re: Interior Dome and Courtesy Lights
jd-
While you could wire it up that way, thats not the way it was done originally. Basically, the dome/courtesy lights have power at all times. The door pin switches or the instrument panel dimmer switch provides the ground source. No relays are used. I've dealing with a similar little project on my K5. Since the K5 top only has a dome light on the side above the driver seat, I added a rear view mirror with map/courtesy lights from a 91-93 s10 blazer. Made one error in my wiring. I did hook the power for the lights to the same as the dome light, but did I hook up the ground to the dimmer and door pins. so they don't work with the door pins. Now I've got to dig around in the kick panel area to tie into the door pin for ground to make it work with the doors.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
#3 | |
Parts and more parts
Thanks for the imput! I would have eventually have figured that out. NOT....lol.... The previous owner had all the wires cut off. I will have to figure out which wire that I will need to tap into coming off of the dimmer switch. Any ideas which color? I guess that I will have to trace it from the light under the dash. Wish me luck. If I figure it out I'll let everyone know.
Gentleman Jim Driver
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Look at the wiring circuit and find the wire that comes from the light switch that comes on when you turn the headlight switch to the "DOMELIGHT" position. That is the one that you want. Most dome light cicuits are orange and white wires. This should be easy to figure out.
The Crazy Machanic
looks good i need to get mind to work as well but i keep blowing fuses when i put a bulb in the rear out side light. Let un now if it work i might have to try that
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
