Old 04-27-2002, 01:57 PM   #1
Fast68Chevy
Fast68Chevy's Avatar
Post alright, the oil pressure sneding unit whipped me...
ok i know this has happened ot others, so i need ot know what you did when the warning light style of oil pressure sending unit brass adaptor deal snapped off in the block, it just happened to me when i went to stick the 9/16" wrench on it to unscrew it in order ot convert to gauge type pressure line/hose connector. yes stupid things like this always happen, thats just how it always goes, now i cant put intake on until i solve this little dilemma.. guess I will go rebuild driveshaft now,.
and does anyone have one of those oil pressure line brass deals that screws intot he pressure hole ? i have everything else, dont feel like buying a whole kit just for the connector..
thanks for anything
Randy- Lincoln, IL
r68c30@hotmail.com 2177353230
-71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not)
-84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,,
-84 Firebird SE 2.8L T-5, rod knocking, dammit,,
-82 Firebird 350 4bolt (TBL)/TH350, not running, dammit...
buy/sell/hoard/trade most any GM vehicle parts of any kind
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 04-27-2002, 02:18 PM   #2
Benrs86
Benrs86's Avatar
Post
tried an easy-out??
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 04-27-2002, 04:11 PM   #3
Fast68Chevy
Post
not yet, i gotta find one over at stepdad's garage if i can, wonder what size will work, anyone who has done this know right off hand what size would fit in the ID of the fitting ?
thanks
Randy- Lincoln, IL
*Paint is overrated
Old 04-27-2002, 05:17 PM   #4
COBALT
COBALT's Avatar
Post
Well...try the ease-out (the cork-screw type if you can, and not the square type). I don't know what size would work yet.
Something else...since the block is steel and the fitting is brass you might be able to drill the center and re-tap the hole, then use cutting oil and air to clean out the hole. Brass is soft, and will yield to a tap made for steel...
just an idea.
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 04-28-2002, 04:39 AM   #5
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Post
The sending units from the 3rd gen camaros and monte carlos work with a pressure guage wihout the mess of a oil line, and are reliable. I put in a 't' on all my chevy's ane use an idiot sender too, so have a guage with a warning light too, same for temp, I have cracked at least 10 I6 heads before I got snart.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 04-28-2002, 12:23 PM   #6
Fast68Chevy
Post
what do you mean is pressure but without line... thats gauge with the warning light type looking sending unit, hmmm, i have one on ethe 82 Trans Am, hmmm i wonder.. actually the frickin one on this engine i was removing was an electric gauge 86 burb one, so... techniclaly i didnt need ot remove it in that case, but if it broke off so damne easy then it needed attentin anyways, gonna melt some candlewax into the threads and pray, the EZ out is biting into it hard but the damn fitting is siezed int he block badly.
thanks
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*Paint is overrated
