Dave's not here, man
Need Ideas for Mounting Booster
I am in the process of swapping to disc and am trying to get the booster mounted. The brackets don't line up with the bolts on the firewall. For those of you that have done the late model booster swap, how did you make the brackets fit? Thanks in advance for the ideas.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Re: Need Ideas for Mounting Booster
maybe getting the proper brackets would be a good start
Dave,
i am with you on this mission..... i am cosidering doing about the same thing... i would like to be able to tuck the booster in close to the firewall
Son of a gun
If it is a 73 and up bracket you can use it. Use the bottom 4 holes and (if you want clean it up a little) cut off the upper portion of the bracket on both sides where the upper holes are. There is info in the archives about using that newer bracket.
Bill BEATERS ARE NEATER |
Hellasick
![]() Join Date: Jul 2006
I just did this, put an 85 in my 70.
You can't just change the brackets as stated above, as they are rivoted(?) onto the booster, not bolted like the pre-'72's. The big problem is the booster will hit the shift linkage on the automatic, it is just too close to clear it. link to my job. http://67-72chevytrucks.com/vboard/s...d.php?t=238199
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 05-10-2007 at 05:47 PM. |
i took a 73 up booster that was shot out of an old parts truck from a buddy and i dismantled the booster drilled out the rivits and popped them out with a hammer and punch i then had to drill out the holes a bite to make it fit just right now all i have to do is attach it to my fire wall wen i get some time but yes it looks like it should work
Designated A-hole!
I used the middle holes for the bottom and drilled my own holes in the top, trimmed off what I didn't need (or was in the way) and it bolted up real nice.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
