Air ride controller and compressor setups
Wondering what everyone runs for compressor and controllers on their air ride setups.. I'm really not intereste in hopping and stuff. Just want to have basic controls of ride height. So i guess i just need like a twin gauge and switch setup. What size tank and compressor should i run? What about solonids? Thanks
Mike 1972 LT1/4l60e Short Bed ART Front and Rear Strong Arms http://www.67-72chevytrucks.com/vboa...50#post2151750 |
Junior Member
Re: Air ride controler and compressor setups
In my daily I am running old school style two analog dial gauges with four electric rocker switches.... my 61 is all new Ride Pro E2 electronics
What kinda valves you running?
i'm running an Air Zenith w/ SMC valves and just reg switches.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
Chevy Truck Addict
![]() Join Date: Aug 2006
I'm like you and am using my airbag system for ride quality and height adjustment... No hopping for me. I purchased the complete Air Ride Technologies Air Management kit (ARC1001) for $500.
http://www.ridetech.com/productinfo/rideproe.asp They list it as a 4 wheel Econo system and includes the compressor, tank, dual needle gauge, all fittings and airline required to get you up and running. It is really simple to hook up too, The valves are built into the gauge and the wiring is nice and simple... It only requires a power feed to the compressor and a "dash light" connection at the gauge. Pretty low end for some folks on the board but it is going to work well for what I need for my truck.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Ever heard of Beech Island??
I love that switch holder
here's an old one.
Yea i was look at SMC valves on ebay. Then i just need to find a controller and compressor.. I think ART has a couple controllers on sale..
Re: Air ride controller and compressor setups
Are SMC and Parker Valves comparable? What othere valves are good? For a basic setup should i get 1/2" or 3/8" valves.. Thanks for the help..
I used this one, cost me $30 on ebay.
I would stay away from 1/2 valves. 3/8 are a lot more controllable. Use 3/8 lines as well, they are a little easier to run too.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Cool thanks for the input...
keep us informed when you put it together im verry interested in where you get problems and how you solve them .
im in the proces of buying 3/8 slambags srw valves 2 compressors and a big tank i only want the front and back go up and down dont want the side to side , i've been looking intoo the same system for leveling . it looks great and will prolly work great too but for now i will try manual and if im able to spent a bit more upgrade to the ridetech stuff . i'm planning on doing a c10 frame of and while im at it replace the axles by c30 stuff and turn it intoo a dually , mostly gathering materials now , prolly will take another 2 years or so to start on the truck i only have boxes sitting now .
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#13 |
hillbilly
how did you get the switches in there?
-1962 C-10 |
#14 |
i think it has a hole in the bottom , it IS a nice idea never seen it before , let see how long it takes before someone starting to put the knobs on a barbiedoll
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 05-14-2007 at 05:08 PM. |
#15 |
Insert Title Here
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#16 |
i rest my case
#17 |
hillbilly
lol
well anyways what is the best setup for switches i just want to lower and raise it back and front not side to side how many switches do i need?
-1962 C-10 |
#18 |
I liked th 7 switch setup I had. Every now and then, I had to bump up a corner because they wouldn't fill even 100% of the time. So having a switch for each bag proved to be worth while even if I didn't use it a whole lot.
#19 |
hillbilly
if you ride the truck low will it be out of alinment? i have heard about the rear pinon angle but how bout the front?
-1962 C-10 Last edited by 62chevy302; 05-14-2007 at 09:28 PM. |
#20 |
When you get your front done, set it where you want your ride height to be (with Slam Specialties, you want it to be about 3" inflated for best ride) and get it aligned there. Higher or lower and you will be out of alignment, but you won't be driving it far at that height, so it's not a big deal.
#21 |
![]() Join Date: Aug 2005
Anyone use any of the Auto Pilot line of digital air controllers that SD carries?
#22 | |
hillbilly
-1962 C-10 |
#23 | |
#24 | |
I know with the RE7, the overall measurement would be about 5". Thanks for clearing that up.
#25 |
learning learning learning , going to need more paper to take notes
