Old 05-10-2007, 05:46 PM   #1
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Lightbulb Coil spring info for my 70' GMC.
Need a pair of front coil springs for my 1970 GMC 1/2 ton LWB. Does anyone know if later model front coils would fit. Want to buy used, auto wrecker has lots of later model coils but no 67 to 72 stuff.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-10-2007, 10:56 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: Coil spring info for mt 70' GMC.
Not the be-all/end-all, but I checked at AdvanceAutoParts(part of PartsAmerica), they have a "see what this part fits" feature, and they list springs only up to '72, supposedly after '72 they are not the same.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 05-11-2007, 10:04 PM   #3
EAST SIDE LOW LIFE
Thumbs up Re: Coil spring info for mt 70' GMC.
Thanks 70C10,
You were a big help today and I appreciate your reply.
esll.
Old 05-11-2007, 10:40 PM   #4
smbrouss70
smbrouss70's Avatar
I would think that the 73-87 front coils would be either the same or VERY close. They share the same suspension set-up (with a few minor differences) and they would have to be carrying a similar amount of weight. Used springs have got to be in-expensive, so it wouldn't cost to much to give it a shot.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-12-2007, 08:01 AM   #5
The Hollander cross-over book should say if they`re interchangeable.All junkyards have them.
Old 05-12-2007, 09:27 AM   #6
EAST SIDE LOW LIFE
Thanks for the posts and all your help .... as I've said before and I'll say it again this is a great forumm! (Geat members.)
Two Island members where I live have PM'd me and I now have 3 sets of coils to choose from.
Again thanks for the posts .....
esll.
Old 05-12-2007, 11:23 PM   #7
71Chevystepside
Long story short, I bought a 77C10 2wd for the motor and trans and found that the front springs looked the same as my 67-72 trucks springs, I took them out and have kept them, they are identical in shape, height and even coil wrap diameter. So I would guess that 67-late 70's at least would be the same or interchangeable....
Hope that helps.....
71Chevystepside is offline   Reply With Quote
Old 05-13-2007, 02:31 AM   #8
EAST SIDE LOW LIFE
Every little bit of info. helps for sure.
Thanks,
esll.
Old 05-13-2007, 07:19 AM   #9
70GMCer
70GMCer's Avatar
Re: Coil spring info for my 70' GMC.
Yes, they fit......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
