Old 05-10-2007, 06:11 PM   #1
70C10Toejam
Hellasick
70C10Toejam's Avatar
another crank pully question
I just got a 2-groove pully, to add P/S. Will it matter that it is 1/2 inch larger in diameter be a problem? The single is 6 3/4 and the double is 7 1/4.
First is the double installed, the single has the same alignment issue that you see between the crank pully and the waterpump pully (and also the alt).
Second one is a bad one of the single as orig. installed.
Can I just shim behind the alt mounts and call it good?
Haven't got the PS pump on just yet.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 05-11-2007, 06:26 PM   #2
70C10Toejam
Hellasick
Re: another crank pully question
