Old 05-10-2007, 08:17 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Detroit Locker or No?
This is the rear axle from a 1972 C-20. I Would like to know if this is a locker or not. I don't know what to look for....Hope you can tell from the pictures.
I finally found the ratio, it is stamped on the inside end of the pinion shaft, 41:10 as shown in the pic. That would be a 4.10:1, could I be lucky enough to have a locker too??? Thanks for any help you can offer.
LockDoc
Leon
Old 05-11-2007, 06:31 AM   #2
dwaite72lnghrn
Re: Detroit Locker or No?
I would say no. As you can see the spider gears that would be replaced by the detroit.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 05-11-2007, 09:52 AM   #3
LockDoc
LockDoc's Avatar
Thanks Dave.
What would you see where the spider gears are if it was a Detroit?..
LockDoc
Leon
Old 05-11-2007, 12:17 PM   #4
1969 GMC
1969 GMC's Avatar
Originally Posted by LockDoc View Post
Thanks Dave.
LockDoc
That dark mark is just a grease smear, but you get the idea
just smooth metal, you might also see a spring above the smooth metal. but as long as you don't see gears, you're good.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-11-2007, 03:28 PM   #5
LockDoc
LockDoc's Avatar
Thanks Adam, looks like some kind of smooth disk or gear case in there.
LockDoc
Leon
