Old 05-10-2007, 10:08 PM   #1
msgross
msgross's Avatar
Dana44 vs. Corp 10 front axles..
OK, After undergoing this swap I have found a few differences between these axles.... I am comparing a 1976 Dana44 with closed knuckles and a 1982 Corporate 10 - both 6 lug 1/2 ton.
The obvious (1/2 ton models)
1. Dana44 30 spline - Corp10 28 spline inner axles (so i've read)
2. both have 32" spring widths (centers)
3. differental on corp10 is moved approx 1" towards the center of the truck, thus the driver axle is shorter and the pass axle is longer than dana44
4. 68 Dana44 is 2.75" tube and 82 Corp 10 is 3" tube (like 12 bolt)
5. Brake calipers are similar except that the corp10 uses a metric banjo bolt, and rubber line is different.
6. Spindles transfer between them but I noticed that the Corp 10 spindle's shaft is larger.
Now my dilemma is that I need to find spring plates to work with the u-bolts.. EDIT:The Dana44 plates might work if I bend the u-bolts 1/8" on each side during installation.
WTB thread
http://67-72chevytrucks.com/vboard/s...d.php?t=240454
Feel free to post more info that you have found... I also now have four u-bolts for a dana44 and need to find the larger spring plates and pay $30 more for u-bolts!
Dana Spicer D44
View Parts List
10 bolt cover with 8.5" ring gear. Found in both front and rear applications. Rear applications use a bolt in axle. Axles are 30 spline. Front applications came in both standard and reverse rotation.
Ring Gear Diameter: 8.5
Ring Gear Bolts: (10) 3/8 x 24 RH
Cover Bolts: 10
Carrier Breaks: 3.73 / 3.92
Spline Count: 1.375 / 26
Float: SF or Front
Semi-Float Type:
Pinion Support: False
GM 8.5
View Parts List
10 bolt cover with 8.5" ring gear. Ring gear has 10 bolts and pinion has 30 spline. C/clip rear could have 28 or 30 spline axles.
Ring Gear Diameter:
Ring Gear Bolts: (10) 7/16 x 20 LH
Cover Bolts: 10
Carrier Breaks: 2.56 / 2.73
Spline Count: 1.625 / 30
Float: SF
Semi-Float Type:
Axle Lugs:
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-11-2007, 12:22 PM   #2
1969 GMC
1969 GMC's Avatar
Re: Dana44 vs. Corp 10 front axles..
The later model 10 bolts (front and rear) switched to 30 spline shafts in '88 IIRC. That's about all I can add.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-11-2007, 06:14 PM   #3
msgross
msgross's Avatar
I did find that the hole in the knuckle (where axle slides in) is slightly smaller. I tried to put a dana44 axle into the corp 10 and found most of this out...oops
The Garage:
Old 05-11-2007, 07:02 PM   #4
62 short step
62 short step's Avatar
MSGROSS I know this is off topic, but killer chopper video. AC/DC awesome!!!
62 short step is offline   Reply With Quote
Old 05-11-2007, 08:25 PM   #5
msgross
msgross's Avatar
thanks... I fly Blackhawks so we don't really shoot at anything. (my door gunners do) I use to show that video to school kids that would take tours at work.... really gets them pumped up...
The Garage:
Old 05-11-2007, 09:25 PM   #6
62 short step
It got me pumped up too!!!
