![]() Join Date: Dec 2001
Hei and Tach
Just finished my instrument cluster and put in stock repro tach. Installed Hei distributor couple of years ago. I would like to know if I connect the 12v wire from the back of the tach to the power wire going to distributor?
Thanks, Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
Oilfield Trash
Re: Hei and Tach
you can if you really want to, i just hooked mine up to an ignition switched 12 volt acc plug on the fuse panel.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Re: Hei and Tach
Re: Hei and Tach
I thought there was a provision at the dist. to hook up the tach. I know that is where I hooked mine to.
esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
Re: Hei and Tach
There is but there is also 12v wire to connect.I was wondering whether I could tie in to wire I've got connected from fuse box to 12v side of distributor from 12v side of tach. I hope this makes sense.
Re: Hei and Tach
hook it to any switched 12v source and you should be good to go.
Look at your fuse panel, and you may have an open terminal (for lack of a better term) you can use ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Re: Hei and Tach
Thanks, guys
Re: Hei and Tach
also make sure that the wire you hook up to is hot in the crank position and in run, but not acc
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
