04-28-2002, 07:37 AM | #1 |
REAREND (OPTIONS)
I am trying to weigh my options. I have a 70 1/2 with 12 bolt 308 rearend (coil). I want to go with 5 lug 373 if I could only find one. My other option is to change to Ford 9" and then what kind of modifying would be necessary.
The easiest swap would be out of a 71 or 72, direct bolt in but I am unable to find one. Also airride suspension will be installed if that makes a difference. Thanks in advance. Located in NC ------------------ Ken
Ken Smith 99 C5 Torch Red Coupe 85 Chevy Candy Apple 70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump, |
04-28-2002, 09:07 AM | #2 |
The 3.73 coil rear should be one of the easiests to find. Most 6 cylinder trucks will have 3.73. If you are looking for posi also it may be more difficult. Just keep scrounging junkyards and post on the parts board. One will show up when you least expect it. I think spending a ton of money on a bolt in 9" is foolish.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
04-28-2002, 10:39 AM | #3 |
You can get a 71 or 72 rear end and it will be a direct replacement, except for brake lines. You can also get a Lincoln Versaile (spelling?) rear end. Its a 9" Ford with disc brakes and a 5 on 5 bolt pattern.
------------------ '69 CST Short fleetside Lowered, 400 small block, 700R4, 3" dual exhaust, 40 series Flowmasters, 4 wheel disc brakes, all stainless hard and flex lines, front & rear sway bars, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims Not my daily driver. More like my weekend A$$ KICKER. See my truck at: http://www.geocities.com/low69cst/ Future Automotive Engineer attending the University of Kentucky. Feel free to message me on AOL, SN- SS95ZQ8 My Dad's projects: 72 Short Fleet 4x4 Chyenne Super 72 Long Fleet 4x4 Chyenne Super Both 350 autos restored original
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
04-28-2002, 11:33 AM | #4 |
its all about the +6 inches
I read a little about that Lincoln piece...it isn't as good as everyone makes it out to be...and good luck finding one too.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-28-2002, 12:00 PM | #5 |
OK whats the low down on the Lincoln rears? I to have always heard to stay away from them for one reason or another. Yet every time I come across one in a yard the rear is missing so they can't be that bad. I believe they are the big bearing housings & I've definitely heard the discs were problematic but that could simply be fixed w/a Explorer/aftermarket disc set-up. They usually came w/3.00's but 9" rears are known for their ease of changing ratios. Anyone have the actual width on this rear or know if early/late rears differ? I know early years got 5 on 5 bolt pattern but if it's more than 1 or 2" shorter different offset wheels would add to the trouble factor when swapping into our trucks. Anybody done this? Any info on this would be appreciated. Thanks, Scot
04-28-2002, 12:15 PM | #6 |
I'll see if I can find the info on it. It was published in a mag about 1 1/2 years ago.
04-28-2002, 12:20 PM | #7 |
Thanks Longhornmail!!
04-28-2002, 12:26 PM | #8 |
well 250 engines got ,373 std equipment ands 3.73 was always, std equipment axle on all 67-72 1/2 ton trucks including 4x4.
when you ordered the turbo hydramatic tranny or the chevy 4 speed then 3.07 came with=, thats how it worked. and in 71 and 72 thjere were ALOT more 350 and th350 trannies installed than anything else, they are way common, and so then technically in 71 72 the 3.07 is alot more common than 3.73, i find 3.07 all the time under these 71 and 72's, if its an auto trans or 4 speed originally, then its 90% chance of being a 3.07 gear. you can use a 64-72 axle, they al wil bolt in, just that 64-70 are 6 lug, but it sill work, you cna worry about going 6 to 5 later on, the 3.73 are way more common before 71 good luck ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
06-01-2002, 11:08 PM | #9 |
If anyone is interested in 5 lug rearends out 71 or 72 Chevy truck I know where a few are.
Just let me know if interested.
06-01-2002, 11:26 PM | #10 |
I did the lincoln rear swap about a month ago. Very happy with it.Overall width is 63 1/2 inches. Exact same width as the 12 bolt five lug rear i removed. GENE
