Old 05-11-2007, 12:21 PM   #1
stunna
frame mounted brake booster master cylinder
Does anyone have pictures of a brake booster/master cylinder that is frame mounted? or does anyone know of someone that sells some sort of kit for this.
stunna is offline   Reply With Quote
Old 05-11-2007, 01:00 PM   #2
XTRMRCR
XTRMRCR's Avatar
Re: frame mounted brake booster master cylinder
Very $$$, but these guys have one: http://www.abspowerbrake.com/
XTRMRCR is offline   Reply With Quote
Old 05-11-2007, 02:12 PM   #3
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
I was gonna try to run this, but I am not sure if I can fit my 2" exhaust between this and the tranny? Any thoughts? I would love to do this and completely shave the firewall, but not if I have to sacrifice my exhaust...........................Bamm!
http://cgi.ebay.com/ebaymotors/UNIVE...mZ110123180099
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 05-11-2007, 04:09 PM   #4
shifty
Questionable
shifty's Avatar
SSBC makes one as well.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-11-2007, 04:38 PM   #5
seanu
Too many projects!!!
seanu's Avatar
Keep in mind that alot of those under floor units are designed for the old 30s thru 50s cars/trucks..and a lot of them had panels that you could remove on the floor to get access to the brake stuff...how are you gonna check and fill your fluids?
I would look for the units that have the remote reservoir...
Sean
1995 Buick Roadmaster Sedan
2004 Chevy Trailblazer 5.3L V8
1963 Chevy Biscayne 4D Sedan
1971 Chevy C10 (now have 70 cab & frame)
1968 Chevy C10 (parts for the 70)
1991 Oldsmobile Custom Cruiser (Chevy 355 motor)
1937 Pontiac 8 4D Touring Sedan (in pieces)
Jacksonville, Florida
seanu is offline   Reply With Quote
Old 05-11-2007, 04:51 PM   #6
Bamm
Bamm's Avatar
I just figured I would do it the same way, Fab a small door to access it. If I could figure out a way to route the exhaust that wouldn't run it right beside the booster/master cylinder, i wouldn't hesitate to do this. Any idea's? ..........................Bamm!
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 05-11-2007, 05:11 PM   #7
cdowns
cdowns's Avatar
i dont see that there'd be a problem with running one guys with model a's and t's as well as 30's-40's cars have been running them for 75years or so with dual exhausts and those frames are a heck of alot narrower than the 67-72chevy trucks as far as access there's hundreds of different premade trapdoors available in steel stainless steel aluminum weld in screw in rivit in and glue in// about the only extra thing you need in these underfloor systems are the residual valves// speedway motors is a great source for this type of brake equipment and thier catalogue has good illustrations and explanations of whats required
Old 05-11-2007, 06:19 PM   #8
Bamm
Bamm's Avatar
Here's a pic I've had of one that was started, but as you can see there is no exhaust run yet.
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 05-11-2007, 06:21 PM   #9
Bamm
Bamm's Avatar
If you were to run a 2" exhaust in between the brake booster/MC setup and the transmission, do you think that would be too much heat around the brakes?
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 05-11-2007, 07:03 PM   #10
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
You could put the exhaust outside the frame if you're running manifolds.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 05-11-2007, 08:05 PM   #11
cdowns
cdowns's Avatar
you could make up a heat shield from state of the art place like www.thermotec.com // a friend of mine built a car with an 800+hp nascar cup engine and had no problems with heat issues
Old 05-11-2007, 10:04 PM   #12
Bamm
Bamm's Avatar
Sorry, I have already bought new jetcoated 3/4 length headers and a pair of Summit Stainless Steel mufflers......................Bamm!
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 05-11-2007, 10:05 PM   #13
Bamm
Bamm's Avatar
Thanks for the link cdowns, I'll check them out. I've got a good friend that works at Hendricks Motorsports, I'm gonna give him a call and see what he thinks of the situation..........................Bamm!
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
