I am trying to replace my axle seals but ran into a snag. After I removed the diff cover I tried to remove the lock screw that holds the pinion shaft in. The damn lock screw snapped probably about mid way in the threads.
72 C10 lwb fleetside -stock 350/350 combo |
The Older Generation
Re: Help, how do I remove this??
Probably the best thing you can do is put it back together so you have something to drive until you can find another rear end...... The chances of getting the end of the bolt out without having to destroy something is slim to none. There was a thread on this a month or so ago so you might do a search on it. LockDoc
Here are a couple of threads on the subject..... ![]() http://67-72chevytrucks.com/vboard/s...ht=remove+bolt http://67-72chevytrucks.com/vboard/s...ht=remove+bolt LockDoc
Thanks Lock, I'll check these out.
Born Psycho
![]() Join Date: Feb 2001
There is a special tool to drill that bolt out--it comes as a complete kit. it's really simple to do and quite common, i've taken out several over the past 22 years of turning wrenches for a living. not sure if parts stores carry them but snap on, matco and mac tool trucks all have them.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#6 | |
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Do you guys happen to know a part number or anything for that special tool? I can't seem to find it.
