67-72 Addict!
I was replacing my turn signal cam the other day and now my flashers don't work in the dash. They work outside the truck. My turn signals do still work in the dash. My flasher switch is new. Is it possible when I had the cam apart I didn't install the brass contacts back the way they were. I switched these contacts and 4 little springs over to the new cam. My cam and switch are the 67 style. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 09-11-2002 at 01:00 PM. |
if any lights anywhere flahs the id be looking at bulb problem or bad contact at bulb base problem or ground problem at back of dash, sounds like may be time for scrwewdriver and WD40 and some housecleaning on the dash.
good luck |
