05-11-2007, 09:59 PM | #1 |
307 to 454 swap
hello i need some help i have a 70 chevy half to that had a 307 i bought a 454 everthing mounts up but when i put the headers on they hit the motor mounts and i lack about a inch the motor is a 73 block but it was in a 83 half ton what can i do or do i have to change the mounts thanks shannon
05-11-2007, 10:48 PM | #2 |
Re: 307 to 454 swap
I am guessing you used your old Small block engine perches??? That may be your problem. If you used big block mounts then I am not sure.
05-12-2007, 01:41 AM | #3 |
Re: 307 to 454 swap
I had the same problem, you have to buy an after market pair or a set of 72 BBC stands. They may cost a lot but it will save you the time of pulling it in and out!
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!! |
05-12-2007, 02:22 AM | #4 |
Re: 307 to 454 swap
sounds like its the mounts
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
