Old 05-12-2007, 07:40 PM   #1
59chev
59chev's Avatar
3 speed gear ratios 59 chevy
Hi Guys,
I have a 59 Chevy pickup with a 62 261 and the original 59 3 speed. I have the stock 3.90 rear end. My 3 speed is wore out (keeps jumping out of 3rd) and I have decided to replace it with a t-5 5 speed. Can anyone tell me what the gear ratios were in the stock 3 speed so I know what 5 speed to get?
For those of you that have done the 5 speed swap, what gear ratios are you running? what's your rear end ratio?
59chev is offline   Reply With Quote
Old 05-12-2007, 08:03 PM   #2
larry may
Smile Re: 3 speed gear ratios 59 chevy
59 Chevy Check out this link they list ratio information for most every transmissions known to this board then some. Hope this helps. Last link is another bit about 5 spds and rear end ratios..........Good Luck Larry
http://www.hotrodders.com/forum/tran...n.html771.html
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 05-12-2007, 08:33 PM   #3
59chev
59chev's Avatar
Larry, this link just takes me straight to the Hotrodders Bulletin Board main page, do you have the complete link?
Old 05-12-2007, 08:58 PM   #4
larry may
Let me check it out . When I copied the link the transmissions were right there when scrolling down a bit. Let me relick my calf and see it they show up. be back Larry
Old 05-12-2007, 08:59 PM   #5
solidaxel
solidaxel's Avatar
Do the T-5 gear boxes have different gear ratios?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-12-2007, 09:01 PM   #6
larry may
How about now? If not scroll down on the home page that showed up in the a bove post about three topics and click on transmissions and rearends. This link should be there. Try them both .Good luck Larry
http://www.hotrodders.com/forum/transmission-rearend/
