Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 05-12-2007, 10:06 PM   #1
jamie72
jamie72's Avatar
cleaning aluminum intake
hows is the best way to clean an intake while still in the truck??
what products to use?
thanks jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-13-2007, 01:56 AM   #2
Mudder
Mudder's Avatar
Re: cleaning aluminum intake
You have to be careful what you get this stuff on but I used to use Eagle Mag cleaaner. It's an acid based wheel cleaner. A small brush and some water rinsing it off.
Mudder is offline   Reply With Quote
Old 07-29-2007, 05:54 AM   #3
71chevytruckguy
71chevytruckguy's Avatar
i use carb cleaner and some paper towels. sway on, wipe off. might not be the best idea to use one a hot engine though. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 07-29-2007, 03:26 PM   #4
mbgmike
I've used that SIMPLE GREEN with some success. Its used better to soak parts though
mbgmike is offline   Reply With Quote
Old 07-29-2007, 06:33 PM   #5
john
member #16
john's Avatar
I would be careful with anything caustic if you have rtv for manifold to block seal.
john is offline   Reply With Quote
Old 07-29-2007, 07:50 PM   #6
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
What is it you are trying to remove? Grease and grunge (GUNK) gas always been good for this, or is it more severe built in stains like oxidation etc. In this case you may have to remove and get it glass beaded.
esll.
Good idea is to clean your engine with Gunk and assess the situation from there.This would be the cheapest and you do not want a dirty engine and a clean intake.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 07-29-2007, 09:52 PM   #7
69swbman
if u know where a blue beacon truck wash (for 18 wheelers) is and if it was off of the truck they have what is called brightner its for removing stains and polish off of aluminum i know i used it on mine i think theres one up there im also a superviser there
69swbman is offline   Reply With Quote
Old 07-29-2007, 11:06 PM   #8
Billla
Billla's Avatar
This is what I use as well, but as noted it's got to be washed off with a lot of water very quickly.
Billla is offline   Reply With Quote
Old 07-30-2007, 08:34 AM   #9
Orange
Licensed to Thrill!
Orange's Avatar
If you just want to make it brighter, Bleach-White doesn't do a bad job.
Tooth Brush + Bleach-White.
Wipe off with wet terry towel.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
