Old 05-13-2007, 06:28 PM   #1
bkg1986
Help Please on air ride!!!!!!!!!!!!!!!!!!!
I am ready to start on my air ride could some give a lise of good setup for front and rear i want to have it as low as possible without cutting up through floor of bed.........i would really appericate the help and could i see some pick of some good setups.....THanks for your help guys.....
bkg1986 is offline   Reply With Quote
Old 05-15-2007, 12:52 PM   #2
Tony@AirRideTech
Junior Member
Re: Help Please on air ride!!!!!!!!!!!!!!!!!!!
What year ?
Tony@AirRideTech is offline   Reply With Quote
Old 05-15-2007, 06:10 PM   #3
bkg1986
1969 gmc shortbed
Old 05-20-2007, 06:55 PM   #4
edflores
just go to ***************** and they will set you up nice. if you want high qiulity high end stuff, air ride had front and rear strong arms for your truck. but for the front i used SD's front brackets and slam specialties bags.
edflores is offline   Reply With Quote
Old 05-21-2007, 10:00 PM   #5
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I used all Suicide doors stuff.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 05-21-2007, 10:02 PM   #6
bkg1986
its leaf springs truck i don't know wat to do in back to match up with 2.5 drop spindles in front and bags...to level it out.....
Old 05-22-2007, 12:46 AM   #7
edflores
leaf springs???? i thought 67-72 shortbeds came with coils? you can order one of ***************** 's 4 link kits, or if you want to go cheap, you can remove some leafs and order some sleeve bags and brackets and a good size notch for the rear. you will still need valves and all that. how much you want to spend?
Old 05-22-2007, 10:22 AM   #8
jimmydean
jimmydean's Avatar
A lot of GMC's are leaf. Your best be is to either use a stock trailing arm type setup, or go 4 link.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
