Old 05-13-2007, 09:10 PM   #1
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Talking getting started on my 67 bed
got the floor painted and have started the bodywork on the bedsides don't know how long this will take ,, here is a couple shot's of what I have to work with ,,,,,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 05-13-2007, 09:12 PM   #2
19673ontree
CAN'T FIX NOTHIN
Talking Re: getting started on my 67 bed
I bet I counted at least 3 dent's
underdash AC
Old 05-13-2007, 09:21 PM   #3
Rokcrln
Rokcrln's Avatar
Looks like a great start, I am a sucker for raw metal bodys. Do you have a shot of the bed floor? What did you use for grinding off the paint?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-13-2007, 09:30 PM   #4
19673ontree
CAN'T FIX NOTHIN
Arrow Re: getting started on my 67 bed
the floor had surface rusted and was sandblasted , I just painted it and am gonna just leave it alone as it will let me use this truck as a truck and haul thing's ,
and as for striping paint 36 grit on a 6'' disc for a drill is the only way to go !!
underdash AC
Old 05-13-2007, 09:40 PM   #5
jsbgump
Gone Fishing
jsbgump's Avatar
I'm debating on taking mine down to bare metal. mmmmm
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-13-2007, 11:06 PM   #6
72CSTC5
72CSTC5's Avatar
OUCH, you stripped the paint with a 36 grit disc!! How wavy is that bed now?
72CSTC5 is offline   Reply With Quote
Old 05-13-2007, 11:09 PM   #7
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Wavy? How about a textured surface.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 05-13-2007, 11:21 PM   #8
Imacarguytoo
If he used this same method of stripping the paint as he did with the front of the truck. Then he knows what hes doing. The pics i saw of the front half of the truck was arrow straight with a killer shine.
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 05-14-2007, 03:34 PM   #9
19673ontree
CAN'T FIX NOTHIN
36 grit to strip a car/truck body is perfectly normal , bodywork is not done with 1000 grit , it leave's the metal clean and with a good base for your first coat of primer to grip , it's just part of it ,
underdash AC
Old 05-14-2007, 04:21 PM   #10
dan42
dan42's Avatar
Looks pretty darn nice to me...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-14-2007, 06:19 PM   #11
Don Brace
Active Member
How many coates of primer did it take to get it that smooth?
Don Brace MN
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 05-14-2007, 06:33 PM   #12
SacramentoJoe
Always Fixing Things
SacramentoJoe's Avatar
I love bare metal, that steel is honest American! It's looking great. 36 is fine. Save your energy for more of that beautiful color sanding that you do. You are lucky to have a shop to work in.
One freak California rainshowers in late May was especially depressing for me.
Just an Average Joe
‘68 GMC 307 3spd – My dad's original truck
310,000 miles
SacramentoJoe is offline   Reply With Quote
Old 05-14-2007, 07:25 PM   #13
abebummy26
abebummy26's Avatar
lmao joe that would suck.
abebummy26 is offline   Reply With Quote
Old 05-14-2007, 10:21 PM   #14
BowTieOgre
Did you paint the truck yourself? If so plz share info on your techniques, materials, tools.
I noticed the can of black Rustoleum...did you use the roller method?
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 05-15-2007, 06:41 AM   #15
19673ontree
CAN'T FIX NOTHIN
the rustoleum is on the bed floor and I just thinned it with laquer thinner and sprayed it ,
as for the did I paint the truck YES I did and am continuing to paint it ,
my method's and tool's are simple
1ST strip to metal with 36 grit 6'' disc
2ND fix any rust big dent's weld cut grind whatever
3RD lay the bondo to it !!
4TH start blocking with 2K primer
5TH continue blocking
6TH block it some more
7TH block it
8TH after you can't find anything else block it !
9TH paint it
10th block the clear starting with 600 then 1000 then 1500
11TH buff it !
12TH RIDE IT !
underdash AC
Old 05-15-2007, 06:51 AM   #16
GREASEMONKEY72
GREASEMONKEY72's Avatar
thanks for sharing that info
i think you should just lay some clear over the bare metal and bolt it up and leave it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-15-2007, 07:06 AM   #17
19673ontree
CAN'T FIX NOTHIN
I did think about just painting this truck flat black and putting a shop name on the door's ,,, I still like that idea
underdash AC
Old 05-16-2007, 12:36 AM   #18
SacramentoJoe
Did you use the polyester or feather fill type primer between blocking? What grit did you use on those? Wish I woulda used a few more gallons of that with maybe an 80 grit between.
Just an Average Joe
310,000 miles
Old 05-16-2007, 04:25 PM   #19
19673ontree
CAN'T FIX NOTHIN
joe here is my step's
I prime with 2K high build primer and sand it with a air file straight sander with 40 grit the first time this is just for getting it straight , then prime it again and sand it with straight line air sander 80 grit , then prime it again and I use a block that was homemade out of a piece of coal mine belt scrapper it's pure polyurethane and will band around corner's or stay flat , I sand will my homemade block for a long while with the 80 grit and then I move to a paint stick with 180 then 220 and finally 320 , after I get it blocked with a paint stick and 320 and it feel's right (YOUR EYE'S ARE OF NO USE FOR BODYWORK) I paint my base then sand it with some 600 or 1000 then clear ,
underdash AC
Old 05-17-2007, 12:26 AM   #20
SacramentoJoe
Great information for folks doin' painting. I also found that the courser grits are the best for getting things straight. I did not spend the effort that you have with multiple coats of high-build and it definitely shows up now that my paint has completely shrunk. I also was afraid to sand and buff the clear coat since it stays outside 365 days a year and thought that might open up the paint and require more maintenance. I found that I pretty much suck at body work, but I am really great at making big piles of bondo dust!
Now I forget that my old truck is underneath that paint.
I like the character of your truck and look forwrd to see it finished. Keep it up!
Just an Average Joe
310,000 miles
Old 05-17-2007, 07:21 AM   #21
n2billet
Village Idiot....
n2billet's Avatar
We strip every car like this without any issues or problems......how do you strip?
n2billet is offline   Reply With Quote
Old 05-17-2007, 09:49 AM   #22
72CSTC5
72CSTC5's Avatar
Me personally, I use a 3M Roloc "black" strip disc to strip my vehicles so I do not put so many deep cuts in the metal. It also keeps the heat down better for less warpage.
