Old 09-11-2002, 05:39 PM   #1
69sixpackbee
How Did You Insulate Your Cab And What Did You Use??
I am sick and tired of the radiated heat from my engine compartment playing tug-o-war with my A/C!
I need to insulate the firewall (outside), underdash and the floor pan. What did you use, how well does it work and haow was it applied???
Thanx!
69sixpackbee is offline   Reply With Quote
Old 09-11-2002, 05:44 PM   #2
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
i didnt insulate my cab from engine compartment but i did my floor from underneath. I used some aluminum/padded heat shielding facing down. My cab still gets warm but not nearly as bad and with the new ac system it's ok. I think any sort of good thermal shielding they sell should work pretty well. also having non UVa/UVb windows does help a lot at adding heat, umm you kinda tan thru your windows. Maybe think about replacing windows and/or tinting them.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 09-11-2002, 06:44 PM   #3
69sixpackbee
...windows are tinted and the cab is in the shade most of the time (cabover camper). I put a digital thermometer on the firewall from inside and the temperature was 227 degrees!!
No wonder it never gets comfy in there!
The windows all have new channels and rubbers. Theh doors have new weatherstripping also and the cab is solid and tight!
I am just getting too much radiated heat from the engine compartment.
Old 09-12-2002, 12:28 AM   #4
Low68
Low68's Avatar
Portable air conditioned garage Sorry
I put some kind of insulation down that just gets glued on with spray adhesive. It seems to help a little. I haven't driven it since I put the new stuff on yet. I had to redo it cause I got a new cab. I have tinted windows also. Good luck
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 09-12-2002, 03:56 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
What about wrapping the exhaust manifolds/headers with one of the heat absorbent wraps. I have heard that it will dramatically reduce engine bay temps, as the bulk of the heat comes from your exhaust, you may also need extra underfloor insulation above the exhaust as the later sections must then get hotter. This stuff is used a lot on race cars. Jegs sell it http://www.jegs.com/cgi-bin/ncommerc...51&prmenbr=361 particularly effective on headers which run hotter than standard manifolds.
Also you can get reflective heat barrier material that you can glue onto your firewall http://www.jegs.com/cgi-bin/ncommerc...81&prmenbr=361 I have something similar wrapped around my starter motor to try and prolong it's life.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 09-12-2002, 04:33 AM   #6
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
The big problem with the wraps is that the heat is replaced by rust.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 09-12-2002, 07:14 AM   #7
Lippyp
English Chevy Owner
Lippyp's Avatar
Does it rust because the wrap holds water? If the man lives in a dry area is this likely to be a problem?
Phil
'67 C10 long fleet.
