Old 05-14-2007, 07:52 AM   #1
Mike C
Mike C's Avatar
Half my 8 lug swap finished
Got the front brakes on my Jimmy. Took a couple of days to source all the parts as usual. I need to get one of my extra rear housings to jig off of for the new rear axles. Wheels are 16.5x10 Centerline Chrome Bullets with 4.5" bs and tires are 36 12.5 Goodyear Wrangler RT II Military bias as used on the Humvee. But here's a shot:
35's are going onto my '52 M38A1 and as you can tell (like most of my projects...), it's half done also..
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-14-2007, 09:26 AM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: Half my 8 lug swap finished
Hey, any progress is good progress! At least we finally had a good weekend of weather to do some work. I like the new Centerlines on the Jimmy
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-14-2007, 09:32 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Looks great! As you know, I really dig that '52!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-14-2007, 12:15 PM   #4
Kool K5
Kool K5's Avatar
Where did you pick up those tires?
And that Jeep looks awesome!!
Evan
70 Blazer 4x4 305/sm465/np205
80 Buick LeSabre Limited
72 Honda CB350F
77 Honda Cb750K
00 Ducati Monster M900ie
Kool K5 is offline   Reply With Quote
Old 05-14-2007, 12:39 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sweeeeeeeeeeeeeeeeeeeeet
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-14-2007, 05:48 PM   #6
dilbert
does the eight lug mean that it is one ton.
dilbert is offline   Reply With Quote
Old 05-14-2007, 06:15 PM   #7
JAKES 68GMC
Aluminum slot wheels rule...
Couple of sweet rides there.
JAKES 68GMC is offline   Reply With Quote
Old 05-14-2007, 07:44 PM   #8
Mike C
Mike C's Avatar
Thanks for the compliments. The 8 lug is from an 86 3/4 ton suburban. I'll be swapping in the semi-floater 9.5 14 bolt as well. The sub was a steal at $300. Didn't have a dent in it and was LOADEd. Turbo 400, NP 261, 4.10 gears, tow package, limited slip (Exploding gov-lok, but hey beggar chooser thing.)
The tires came from Tyres International and were a special: $448 for 4 with free delivery. I got five, $112 for the 5th and free delivery. The wheels were closeouts from Centerline, originally $457 each on clearance for $145 each and once again, I got 5. $1300 for the whole package.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-14-2007, 11:13 PM   #9
Kool K5
Kool K5's Avatar
I just had a look on that site for those tires and didn't find them. Was It a one time special and then they stopped carrying them?
72 Honda CB350F
77 Honda Cb750K
Old 05-15-2007, 09:00 AM   #10
Mike C
Mike C's Avatar
It was a special purchase. I went there as well and it is no longer on the site.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-15-2007, 10:53 AM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Sure was a great tire purchase - they have a current special on some 37" tires for $800 for Dick Cepek radials - no where near the deal you got, but still a pretty good deal.
Old 05-15-2007, 07:45 PM   #12
Mike C
Mike C's Avatar
Yea, only draw back is the ONLY size is 36 12.5 16.5. I told myself I'd not own bias plys again, but hey, I can't say no to a deal!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-16-2007, 11:35 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Even with the size and bias ply shortcomings, still can't beat the price!
Old 05-17-2007, 08:54 AM   #14
Mike C
Mike C's Avatar
That was the conclusion I came to as well and is what separated this fool and his $.
Tried balancing them last weekend, but couldn't get a zero. Everytime I added weight, it just moved around the rim. Called Ranger yesterday. One of the parameters you have to input is whell diameter, and 16.5 is not a choice. WTF? Guy said just round up. I had already tried that.
Monthly you are supposed to calibrate the balancer and the manual says "Note: a standard 14" steel wheel is recommended for this procedure." so I pulled my spare off the car trailer, dismounted the tire, and calibrated the balancer. Explained this to the tech and he said my mistake was not using the wheel and tire ASSEMBLY to calibrate. I pointed out to him that if they wanted me to use the wheel AND the tire, why didn't they say that in the instructions? Will re-calibrate balancer and try again maybe Friday night.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-03-2007, 08:42 PM   #15
Mike C
Mike C's Avatar
OK, got a housing jig built off an old 12 bolt I had and then used the shock mounts on the semi-float 14. It's in the truck, but I still need to do brakes and get a conversion u-joint. But, it did free up the back tires for my jeep! I hope to have the conversion finished this week.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-04-2007, 12:34 AM   #16
Kool K5
Kool K5's Avatar
That thing looks wicked
Evan
72 Honda CB350F
77 Honda Cb750K
Old 06-04-2007, 06:06 AM   #17
vtblazer
vtblazer's Avatar
Nice swap.
36's are the right tire for your SF, good call.
vtblazer is offline   Reply With Quote
Old 06-05-2007, 11:28 AM   #18
Yukon Jack
Post Whore
Yukon Jack's Avatar
The '52 looks awesome!
Old 06-10-2007, 08:10 PM   #19
Mike C
Mike C's Avatar
Thanks. Still making progress. Here is the JImmy with all 4 on it. Couldn't get a 1310 to 1350 joint at the local store. Should be in tomorrow. Brakes work great. I've been motoring around in front wheel drive.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-11-2007, 05:59 AM   #20
vtblazer
vtblazer's Avatar
Looks sweet for sure.
Is it as close as the pics make things look?
Any plans for a little more lift?
Old 06-11-2007, 08:45 AM   #21
Mike C
Mike C's Avatar
Close, but not as close as it looks. No plans for more lift. Mostly on-road use these days and the jeep is the offroader.
I am planning on taking a little more off the front of the rear wheel wells (took about 1" off at the bottom tapering to zero up about 6") like when I went to the BFG's from the Mickeys. I'm also going to trim the "hook" off the fron fenders and weld the box back in. Not only does that give a little more clearance, but it looks better IMO if the front and rear of the wheelwells are the same shape.
If my driveshaft is a little too long, I'll redrill the spring mounts and slide the whole thing back 3/4" or so. I have a Tom WOods CV rear shaft but think I'll have room.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-11-2007, 09:45 AM   #22
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm just continuing to drool over the rim/tire combo!
Old 06-11-2007, 03:42 PM   #23
Mike C
Mike C's Avatar
Thanks Mark. I need to get 'em balanced and then I can focus on the jeep for awhile. I still need to re-do the cage and am going to be doing some panel replacement as well, but that can wait awhile!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-16-2007, 10:20 AM   #24
Mike C
Mike C's Avatar
Well, after getting it all buttoned up, not enough driveshaft travel. I pulled the U-bolts again and re-drilled the hole in the perch forward 3/4". I know have the proper alignement on the slip part of the driveshaft AND it ventered the axle in the rear wheel well.
Gonn'a work on the jeep for awhile, but next for the JImmy will be a new passenger front fender and box the lower front of both. New cage after that.
44 Willys MB
52 M38A1
64 Corvette Coupe
