Old 05-14-2007, 10:40 AM   #1
flatbedchev
flatbedchev's Avatar
Starting problems
I need some input as to what could be the problem with my truck. It's a 72 Chevy with a 350. I charged the battery until it was reading a full charge. I hooked everything back up and turned the key......nothing. I checked all my accesories and they work. Now this thing hasn't had any trouble starting over the past 3 years. I figured it was my ignition switch, so I swapped it out seeing how I already had a new one in my shed. Still nothing. I started at the battery and cleaned all the connections, hooked everything back up and turned the key. This time it turned the engine over but was damn near dead. I need to know how to determine what is drawing the poswer out of this truck. Maybe my battery froze from sitting all winter? but if it froze, would it even take a charge?? Maybe the starter is weak? I have already replaced the alternator and the battery is only 3 years old, but the starter and solenoid are the ones that came with the engine. The engine is a donor from an 82 van
Any ideas?
flatbedchev is offline   Reply With Quote
Old 05-14-2007, 10:57 AM   #2
RustyParts
RustyParts's Avatar
Re: Starting problems
I'd try swapping with another battery if you have one handy or jump it from another vehicle, if it does the same thing you have another problem.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 05-14-2007, 11:14 AM   #3
flatbedchev
I've jumped it from my portable jump starter and it fires right up.
Old 05-14-2007, 11:55 AM   #4
RustyParts
RustyParts's Avatar
I believe it's time for a new battery.
Old 05-14-2007, 03:33 PM   #5
flatbedchev
I pulled the battery at lunch and found acid residue on the tray. Must have froze and broke a cell. I'll be picking one up this week
Old 05-17-2007, 07:11 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Dont be cheap, get a good one
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-17-2007, 08:27 PM   #7
hiridn69gmc
hiridn69gmc's Avatar
I had an issue with my old Nova that sounds simular. My starter was drawing excessive amounts of current. I would charge the battery, or even have a good battery, turn the key and the current draw off the starter would kill the battery.
I took it in to get tested after replacing and checking about everything else. If the new battery didn't solve your problems, it might not hurt to check here.
Hope it helps
1971 Chevy C-10-sold
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
hiridn69gmc is offline   Reply With Quote
