Sway Bar Bushings- Moog
Do the front sway bar bushings (blue moog ones) need to be greased when installed? Mine slipped right on so I didn't grease them. Should I have?
1968 c10 Chevy 2005 Infiniti G35 2006 Subaru WRX STi ![]() Last edited by dmsteele92831; 05-14-2007 at 12:45 PM. |
Re: Sway Bar Busshings- Moog
i always put the silicone grease on the poly sway bushings when i install them thats what the manufacturer reccomends
Is hi-temp grease the same?
1968 c10 Chevy 2005 Infiniti G35 2006 Subaru WRX STi ![]() |
Hellasick
![]() Join Date: Jul 2006
I looked at the Moog web site when I bought mine for this same reason.
According to their site, they do not need greased because they are NOT urithane. They are some kind of plastic that does not need greased. the instructions in the package says to not use a "rubber" lube, so no KY in there.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
Re: Sway Bar Bushings- Moog
Thank you!
#6 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Hellasick
Hope they don't get mad at me...but I took this from the Moog website.
"Our advanced thermoplastic bushings absorb vibration and noise and deliver better handling and longer life, while providing the performance of urethane without the “squeak” normally associated with it. They are not affected by oils, alkalines, ozone or hydrocarbons; can withstand extreme weather conditions; can carry substantial loads; and will not discolor or crack with age."
