Old 05-14-2007, 03:16 PM   #1
jorgensensc
jorgensensc's Avatar
Dumb brake question.
Are the 11" x 2" brake drums on the front of a '56 Bel air the same size as the 11" x 2" rear brake drums on a '68 truck. I understand the bolt pattern is different, but I need the 5 x 4 3/4" pattern. Looking for a way to not have to redrill ,my rear drums.
Thanks!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-14-2007, 06:26 PM   #2
Don Brace
Active Member
Re: Dumb brake question.
First thing I would do is check the diameter of the center hole. Then the thickness of the the drum metal. If they are the same then they may work.
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 05-14-2007, 07:27 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The rear axles will be drilled to whatever patern is on there now.You will still need to redrill the rear axles or swap rearends.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-14-2007, 07:41 PM   #4
jorgensensc
I am going to Buy new moser axles and they will put both bolt patterns on, 5 x5 and 5 4 3/4 for me. I want the 5 x 4 3/4 pattern, so I need drums to fit that pattern. If I ever decide to later I can switch them over to 5 x 5 bolt pattern. preparing for everything.
Shawn
Old 05-14-2007, 07:52 PM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
if the bolt pattern is the same and the center hole will fit over the axle then they should be fine
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
