Before and After
Serpentine belt conversion
I want to clean up my engine compartment a little. One thing I want to do is convert the V-Belts with a single Serprntine belt.
Are there some vehicles that would be a good donor for this? I would prefer to do it that way rather than buy a conversion kit that will cost me an arm and a leg. I don't have A/C, but I have Power steering and an alternator that I will need to connect.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
chevy truck fan
Re: Serpentine belt conversion
wb,
i used a setup directly off of a '92 suburban (it had just got to the yard while i was there). everything bolted right up to my stock style '76 350 block. the only mod was the bracket from the alt. to the exhaust manifold. i have headers & iirc it was to thick around the flange. you will need a "dummy" bracket for the ac if you chose not to run ac. hope this helps... rodstored-72 |
THIS IS THE SERPENTINE BELT SETUP I JUST INSTALLED ON MY 60 IMPALA, LOOKS REAL GOOD, IT'S CALLED "POSI-TRAK" IT'S MADE BY ZOOPS
even a setup off a tpi camaro/firebird will work.
I bought a used setup complete except for waterpump for $125
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
#5 | |
When I had the SBCs in my S-10...I used all the bracket/accesories from the 4.3. It all bolted right up to my 350. It was a late seveties 350.
If you are going to get the brackets at a J\Y get all the accessories (water pump, alternator, P\S pump) braceses and mounting bolts. Water pump is reverse direction, alt has different mounting, P\S is easier to take than removing the pulley and the pump (you can take the fitting on the back of yours and put it in the new pump and still use your old lines). As already mentioned you can remove the A\C pump but you will need to get a dummy pulley to replace it. Depending on what fan you use (I have a large 7-blade clutch fan off a 9C1 Caprice) you may need a BB fan shroud.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 05-14-2007 at 06:28 PM. |
"See the U.S.A....."
Take the fan too because of the reverse rotation water pump uses a reverse rotion fan. I used 95 suburban in mine.
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
Having just helped do this two weeks ago I have to only add this try & get the electric fan too. This was much easier to do than I really expected. Hardest part was using a string to get the right size belt at the parts store. Don't forget anything bolts & hardware you may need them also.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
what radiator hoses did you all go with? Everything else was easy now I just have been picking random hoses from the junk yard and haven't came close yet. thanks in advance.
![]() Join Date: Jun 2006
I have a 89 Suburban serp. setup on mine. Check out my build thread. I actually used some hoses that Brothers sells. Fit perfect.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
I would be interested in the hoses that will work with this setup too as I have a serpentine off a 1991 Suburban and the top hose is giving me fits as I have not found one that will fit yet.
