![]() Join Date: Sep 2006
Help with 700r4
Anybody put in a 700r4? Looking to update my 72. It has the 350 and
NP205. Whats involved and who would I got to if I need adapters. Thanks in advance. |
Re: Help with 700r4
i almost did it with my blazer. i wish i would have, but i didn't have the time or shop that would do it.
you'll need to go to advanced adapters http://www.advanceadapters.com/. some guys on the board have done it. also check the forums at coloradok5.com. i think the 700 is 1-7/8" longer than the 350, but the adapter may take up the slack. otherwise, you might be shifting the t-case back or the engine forward.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ Last edited by cstanley; 05-14-2007 at 06:37 PM. |
Cereal Killer
Re: Help with 700r4
buy the 700r4 and 205 i have for sale and its a bolt in.
If I dont do it....somebody else will. |
Re: Help with 700r4
there is a post int the 4x4 section on the convertion check it out there is a link to a post from a while back that gives you other options besides the advanced adaptors shaft.
Earl 68 2500 4x4 GMC Burb |
Re: Help with 700r4
I installed a 700R4 in my 72 GMC 4X4 in place of the stock 350 trans.
The 700 bolts right up using the same stock adapeter the 350 uses. What you have to change is the out-put shaft on the trans. Advanced adapters make the shaft. The 700R4 is 2.25 inches longer then the 350 so i moved the motor mount cross member forward. This keeps the transfercase in the stock location. This work out vary good even with a big block. hope this helps |
Blazerless
Re: Help with 700r4
I did a 700R4 in my (former) 72 K5. Advance Adapters output shaft for the tranny. Moved engine and tranny ahead 1 3/4". (700R4 is 1 3/4" longer than TH350). Stock t-case adapter bolts up to the new tranny. T-case remains in stock location and stock driveshafts can remain. Moving the engine ahead also gives more room for an HEI distributor. Stock column shifter was used with some "adjusting"
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD ![]() 69' Beaumont 388/700R4 11.70@116 ![]() 77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad. |
Re: Help with 700r4
you can also buy a spacer that goes inbetween the TC and trans I have used both and if I ever do it again it willbe the spacer the short shaft is 150 then you have to have a trany shop put it in it is just to much money when you can get a 50 spacer to do the same thing.
#8 | |
Blazerless
Re: Help with 700r4
Re: Help with 700r4
I had a 6 in lift on my blazer when i did mine so I had longer shafts already but when I went to the 700r4 I did not have to change them again. it didnt add the much to it I moved the engine a head I wanted the extra room for the HEI distributer so my drive lines didnt move the much.
![]() Join Date: May 2005
Re: Help with 700r4
Moved my engine forward, 700 input shaft can be machined down and shortened as there were plenty of spline material, but the outer diameter was not same diameter as you go further up the shaft. Basically, cut shaft 1.5" and make sure diameter is correct to compensate for new shorter length.
Re: Help with 700r4
So what are the advantages of the 700R? I'm new and stupid, pls. help..... J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#12 | |
Blazerless
Re: Help with 700r4
#13 |
Re: Help with 700r4
Thank You, you have enlightened me, sensii
#14 |
Mike
Re: Help with 700r4
Only if you move the transfer case.Putting in a spacer,and moving the engine and trans forward will not change the driveshafts.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#15 | |
Blazerless
Re: Help with 700r4
3 3/4" may be too much.
#16 |
Re: Help with 700r4
the spacer is only like 1 in thick. If you change to an electric fan you will have a ton of new space. you can split the difrenc any way move the engine a head an 11/2in and move drive line 11/2in and you wont have any trouble
#17 |
Re: Help with 700r4
Thanks for the help guys, now I just have to find the 700R.
#18 |
Re: Help with 700r4
IMO Earl's got it pegged. Best way to do it is w/ the spacer, engine forward and transfer case back. The AA shaft leaves you with the front CV really close to the pan on the 700R4. No way to use a deep pan. With the spacer, you have gobs of room and can run a deep pan. Even with the driveshaft mods it's still way cheeper then tearing down the 700R4 to install the AA output shaft.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
#19 |
Blazerless
Re: Help with 700r4
Either way will work. It comes down do personal preference, I guess. Just be sure to use a '87 up 700R4 and get a "K" case tranny. K case has the heavy duty cast aluminum inspection cover with mounts for the support rods.
#20 |
Re: Help with 700r4
Looks like yous guys covered all the bases, thanks for the input. Invaluable information, think I got it strait. J.
#21 | |
Re: Help with 700r4
With the electronic shift kits available now I don't know why a 4L60 wouldn't be a good option.
#22 | |
Oh..never mind....
Re: Help with 700r4
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
#23 |
Re: Help with 700r4
Ouch. Now I know why not such a good option. I thought there were cheeper ones on the market now.
#24 |
Re: Help with 700r4
cheapest I have seen is around 700
#25 |
Oh..never mind....
Re: Help with 700r4
After my first post I went and looked again to see if there was anything new since the last time I looked. I too found a couple in that price range, but then there was another $150-$200 harness to buy after that.Plus one of those needed to be programed with a lap top. I also found a unit that GM Performance sells with everything for about $1100 IIRC. Regardless, not a cheap date to go this route. Still it has its appeal, and I may just hold on my 4L60-E until my cash flow gets better.
