Old 05-15-2007, 12:07 AM   #1
superman3405
Junior Member
superman3405's Avatar
battery drain
I have had the truck sitting still while I work on the body. I had to move it today and dead battery...I hate electrical problems. Here is what I have checked have I missed anything?
Battery cables, cleaned and reconnected
ground, checked all grounds to the frame.
fuse box to see if any drain while truck is off,,,none that I can tell
I think it may have something to do with the fact that I put a 94 amp internal alt. on it recently. I rewired the external regulator as one of the post here explained. Two outside plugs wired togehter and two inside plugs together. Could this be my issue??please help. Thanks a million!
1972 Chevy C-10 Short Bed (Ol'Blue)
350/350TH
2003 Chevy Silverado Z71
2007 Honda MiniVan...yup we should all be so lucky
superman3405 is offline   Reply With Quote
Old 05-15-2007, 07:31 AM   #2
truckdude239
truckdude239's Avatar
Re: battery drain
when i wired my i justr wired the 2 outsides together and caped off the white wire and jumped number i believe it was 1 to the back of the alternator. now i have seen new alternators have bad dideo int hem that will cause a drain off the battery when off unhook the alternator one night and see if battery is dead next morning then you know you problem
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-15-2007, 11:46 PM   #3
superman3405
Junior Member
Re: battery drain
thanks I will give it a try
350/350TH
Old 05-15-2007, 11:50 PM   #4
st1x10
st1x10's Avatar
Re: battery drain
I actually just wired mine. I wired the two outside together and left the other two open. Then capped the white wire and wired the 3rd plug to the blue wire. The 1 plug goes to the battery post on the alt. If you need some pics let me know.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 05-16-2007, 12:07 AM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: battery drain
aint electrical fun
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-16-2007, 12:38 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: battery drain
Here is the correct way to do it.
http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-16-2007, 05:14 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: battery drain
could it just be an old junk battery?
Old 05-23-2007, 02:28 PM   #8
superman3405
Junior Member
Re: battery drain
okay guys I got a new battery today and this evening will be doint the re-wire for the 94 amp internal alt., once I get this done how do I knwo that the trcuk is charging properly and the battery will not be going dead again? I have a multi meter at the house I can test the battery with once it is running, about where should it read?
350/350TH
