05-15-2007, 02:06 AM | #1 |
The Original HotRod KnifeMaker
Ram Air setup, pics please?
I am finishing up my truck this month, will post pics when complete.
I am adding a ram air setup. I want to pick up the air right at the grill. Thinking of this grill mod to allow space for the pickup hoses. I remember in high school we used to collect the air by dumping the inside headlights [4 light systems] and picking up the air through the second headlight housing How are you picking up your cold air for your ram air setups? What are you using for the ends? Thanks,
Dave 69 GMC SWB 2WD 454 Turbo 400 |
05-15-2007, 06:25 AM | #2 |
Re: Ram Air setup, pics please?
you could run hoses to pick up the air underneath the bumper, or cut holes in the rad support and run the hoses from the grill, through the support and to the aircleaner
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-15-2007, 07:07 AM | #3 |
Keep in mind that you don't necessarly need a round hole to pick up the forced through the rad suppot. Had a porsche that picked up air from oval scoups mounted on the top of the rad support --between it and the hood--and routed the cool air back on both sides of the V8 to inlet at the rear of the block at the firewall. (928S4)--it also had air inlets that forced air directly to the front disc's for cooling. Both GM and Ford had dual intake air cleaners for easy hookup. using a GMC firewall would give you the dual hole but ----headlight placement might be an issue. Definitely a nice upgrade that many will watch to see you solution. Huck
05-15-2007, 10:40 AM | #4 |
Planning on running the hoses thru the core support to the grill. Hoping someone has done this and will post a couple of picks
05-15-2007, 11:33 AM | #5 |
Here is the setup I am using for the ram air- still looking for ideas about the actual pick-up collectors. Something a little larger, maybe?
Thanks,
05-15-2007, 12:21 PM | #6 |
what about from the firewall like this type ?
"I feel the need for speed!"... as soon as I am done with my nap. |
05-15-2007, 02:32 PM | #7 |
[ATTACH][/ATTACH]Here is a picture of mine. The PO installed it. I don't know who makes it.
71 Chevy Stepside 377/350 |
05-15-2007, 02:36 PM | #8 |
I've been workin on this project for a while too, just haven't had time to complete any of it past the design stage. http://www.ramairbox.com/ makes the one above.
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
05-15-2007, 03:02 PM | #9 |
aka TEX-TOY
i am thinking about attaching a hose to the firewall so that i can draw in the air from the windshield.... Does anyone have any thoughts on this?
1969 Chevy C10 SWB w/ disk brakes and soon to be lowered with spindles and springs!!!! Getting a paint job like a Army Chinook Helicopter!!!! HOOKERS RULE!! BRAND NEW WIFE BOUGHT IT FOR ME AS A WEDDING GIFT!!! SHE IS THE BOMB!!!!!! |
05-15-2007, 03:39 PM | #10 |
What kind of gains do you all figure a setup like this will give you?
05-15-2007, 03:47 PM | #11 |
There doesn't seem to be much actual measured data- everyone just says 'substantial boost' in HP. A pilot friend says that you have to be going more than 100 mph for any gain from the ram effect. Most everyone agrees that the additional cold air can't hurt
05-15-2007, 03:58 PM | #12 |
71STPSDE, what does it look like going through the core support, and what is on the other side of the core support that is actually collecting the air into the tubes? Your setup looks almost identical to what I want to do- gather up the cold air [or at least colder than in the engine compartment], run it through the core support and then dump it into the air box. I want to use rectangular pickups outside the core support that will stand up and down in the new space outside the inner and outer grill so they show from the front of the truck. Couple more pics, please?
Thanks,
05-15-2007, 04:07 PM | #13 |
That's what I was thinking. I can see a bigger gain on newer cars from opening up a closed air filter box but not so much on one of our trucks. Let me know how it works out though, I'd consider it for mine.
05-15-2007, 04:37 PM | #14 |
05-15-2007, 07:26 PM | #15 | |
05-15-2007, 07:49 PM | #16 |
Real Projects never die
For my k5, i was thinking of using a ram air setup. I was just gonna cut up an old hood and put a mustang-style scoop.
I am interested in who makes that dual snorkle setup, looks like it sits on a 360 degree filter. If someone got me a brand name it would be appreciated. Thanks R.spence
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
05-15-2007, 08:21 PM | #17 |
Something to keep in mind is all the ridges on the hose actually causes turbulance in the air and in some instances hurt performance, so I've been told. Would be nice for a nice smooth hose though.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-15-2007, 08:58 PM | #18 |
I got my setup from Summit, Jegs sells a kit, too. Google Ram Air Box and settle down to read for a while
The engineers say the turbulence is eliminated by the heavy filter, which also is supposed to trap water when it rains. We will see.........
05-20-2007, 02:21 AM | #19 |
Got the core support cut, ran the hoses from the grill, through the support and then up to the dual pickups on the air box.
Gonna just leave it like that until I get it road-worthy again, next weekend. I think I'm gonna search around a little more for a larger, funnel-shaped pickup at the grill. I am not happy with the size of the collector ends and want a little more flow. My mechanic says it is a total waste to spend all this money on a bib block and then quiet down the sounds of the engine suckin' air. He wants the air scoops in the glove box so you can hear 'em I had a cover built for my gas tank filler by a sheet metal/furnace guy. I may ask him to build me something I can live with if nothing else works. Pics tomorrow if I can find the charger for the camera.
05-20-2007, 03:58 AM | #20 |
better find that charger so we can see the pictures
05-20-2007, 10:10 AM | #21 |
71 rustless in texas
WinDancer go back and look at this http://www.ramairbox.com/snorkels.html. The round metal inlets (4/5/6FLC) could probably be picked up at a hardware store or some place that does duct work for less than what ramairbox wants for them.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
