Old 05-15-2007, 09:29 AM   #1
Big Block
Big Block
Big Block's Avatar
Help (from 1ton guys)
I just bought a 1972 Chevy dump truck it has old split rims. I want to get new rims. Called to day to see if I could get new ones and I was told that the 72 has smaller 1/2 studs and the new one use 9/16 studs and larger lug hole. What are you guys with 1 tons using?
Big Block is offline   Reply With Quote
Old 05-15-2007, 10:09 AM   #2
Overkill67
Re: Help (from 1ton guys)
I am still using the stock bud rims on mine.
Overkill67 is offline   Reply With Quote
Old 05-15-2007, 12:28 PM   #3
Chris H
72 C30 Trailer Queen
Chris H's Avatar
1971 and 1972 C30 trucks have the larger 9/16 studs.
According to Accuride's wheel catalog, wheels from 1976-2000 C/K trucks are the same (16"x6", part #29587). These wheels have a 4.56" center bore, and are supposed to be used with a clamp plate and 90 degree cone nuts (clamp plate is GM part #472536).
Previous to 1976, the factory single piece wheels were 16.5", and they will work too.
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 05-15-2007, 03:12 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
chris is dead on.
Old 05-15-2007, 06:27 PM   #5
RicksTrucks
RicksTrucks's Avatar
Adding to your herd I see.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 05-15-2007, 08:36 PM   #6
Big Block
Big Block
Big Block's Avatar
Thanks for the info Chris and Longhorn Man. I have never owned a 1 ton before. Rick, I'm going to build a shop. I need to put in new driveway in and patch up the road in front of my house. I'm going to be making a lot trips to the stone quarry. The good thing is that it is about 10 miles from work. I can get a load on the way home.
Old 05-16-2007, 01:33 AM   #7
alschevy
hi yes the old split rims are no good any more they can take off your head
or kill you if you dont know what you are doing every who has a one ton is going with bud rims its a nice thuck would like to know more about it
1967 chevy one ton duaily wrecker truck
alschevy is offline   Reply With Quote
Old 05-16-2007, 01:42 AM   #8
longhorn71
longhorn71's Avatar
all the 1-tons here ran the 18" wheels in 67-72.they were also split rim.my 72 I put a set of newer 16" rims and plates on it.I needed to put longer studs in the hubs for the plates to fit.
longhorn71 is offline   Reply With Quote
Old 05-16-2007, 06:30 PM   #9
Big Block
Big Block
Big Block's Avatar
I ran road service for Goodyear repairing truck tires. That job will make a man out of you. 18x19.5 tries on cement trucks were not my favorite. Ther are several types of split rims. The ones that split in the middle are the worst. I won't touch them. You never know if they are going to stay together. The others are not so bad. I will be removing them as soon as I can locate replacements. The truck was used on a farm. The front tires are old nylon bias plys and are dryrotted the rear are the same. The cab is rusted out but the dump bed works great. After I get the new shop up I'll think about replacing the cab. For now just an old work horse.
Old 05-19-2007, 09:20 PM   #10
Big Block
Big Block
Big Block's Avatar
Okay, I got used wheels off a 76 1 ton dually. Lug nuts and plates. Now I have to replace the front studs, too short. No problem I can do the front studs. Now what is it going to take to do the rear studs? Will I have to take the axles out?
Old 05-20-2007, 01:14 AM   #11
67_C-30
I have a radical idea!
67_C-30's Avatar
My '67 C-30 came with 17.5" 1 piece wheels, and I have a '69 GMC 3500 dumptruck that has the 2 piece 18" wheels.
You will have to take the out axles out to get the brake drums off because that's what the studs are in. You'll have to remove the axle with the 8 bolts out on the hub. Then there is a wide flat nut, that has sheet metal tabs around it that you'll have to bend out the way to get off. Once that's off, you can pull out the bearings and remove the rear drum so you upgrade the studs.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
