Old 05-15-2007, 11:53 AM   #1
70C10FI
Panhard Bar adjustment... How to??
How do you adjust it after lowering to make sure the rear end is lined up properly?
70C10FI is offline   Reply With Quote
Old 05-15-2007, 11:53 AM   #2
70C10FI
Re: Panhard Bar adjustment... How to??
I mean how do you measure the rear end?
Old 05-15-2007, 12:16 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Just measure from inside of the tire to the frame on both sides and adjust to an equal number.But you will need to get an adjustable bar, The stock ones have no way to change the length
sneakysnake is offline   Reply With Quote
Old 05-15-2007, 12:47 PM   #4
70C10FI
sweet thanks- I have an adjustable one, I just wasent sure if it had to be aligned (4 wheel)
Old 05-15-2007, 05:59 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i wouldn't pay a shop to do it, 1/2 of them wouldn't touch it anyways
Old 05-15-2007, 06:11 PM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I would use the rear end back plates as a measuring point and not the tire. Tires and rims can be inconsistant, but the back plates do not move. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-15-2007, 06:19 PM   #7
Longhorn Man
good point wes
Old 05-15-2007, 08:41 PM   #8
jeff"s62
jeff"s62's Avatar
4 wheel alignment not neccessary.
jeff"s62 is offline   Reply With Quote
Old 05-15-2007, 10:05 PM   #9
hiridn69gmc
hiridn69gmc's Avatar
I know mine ended up being a pain in the a**. I finally got it to little less than a quarter inch off and was happy....
1971 Chevy C-10-sold
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
hiridn69gmc is offline   Reply With Quote
Old 05-15-2007, 11:38 PM   #10
jorgensensc
jorgensensc's Avatar
At What hieght do you need an adjustable panhard bar. I'm looking at a 4" drop in the rear. Is it necessary?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-16-2007, 12:35 AM   #11
powell72
powell72's Avatar
I've ran a 4'' drop without one, ECE said it would be fine. I do know a lot of people recommend them with a 4'' though.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 05-16-2007, 06:42 AM   #12
byrd
Union Electrician
byrd's Avatar
Yep the drum backing plate is where I measured mine from and got it within a 1/16" fairly easy,although it took a little time.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-16-2007, 07:07 AM   #13
cdowns
cdowns's Avatar
Shawn
every inch you lower your truck you gradually make the rear end offcenter by the time its 3-4 inches dropped its a noticeable differance in the wheelwell clearance, the truck will still run and drive down the road fine, it just starts to look a bit goofey doin it// personally i've normally replaced with an adjustable bar on most trucks i've owned lowered or not just because the old ones were bent twisted and needed new bushings and i figured the new adjustable bar was a worthehile upgrade
