05-15-2007, 11:54 AM | #1 |
Shocking question????
Going from a 4" to a 6" all spring. Do you think my shocks will survive for a while? Rancho 9000's. They don't really look that extended and there won't be any flexing to speak of, just mostly highway stuff.
05-15-2007, 12:01 PM | #2 |
Re: Shocking question????
how do you like the 9000's? I picked up the on-board system from a buddy ($50) and am looking into getting a set. Will yours only fit 4" lift? let me know if you decide to upgrade and want to sell yours...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-15-2007, 12:08 PM | #3 |
Yes mine are for a 4" and I lovem. They have the 5 settings and you won't tell alot of difference from one setting to another but you can for sure from like 1 to 5. I have used them to control a bad tire that has a lot of weight on it. Seems to ride a lot better when the shock for that tire is set on the stiffer position. Not sure if and when I get rid of them yet. They are painted red !
05-16-2007, 12:38 PM | #4 |
Ttt
05-16-2007, 02:14 PM | #5 |
I am guessing that you need to swap since rancho's catalog has 3-4" lift shocks and 6" shocks. No expert on shocks here so good luck...
05-16-2007, 03:09 PM | #6 |
Nobody rides free
If they have travel in them & aren't totally compressed either you'll be good, especially since it's on-road use. Just give 'em a try & see how it feels.
I put a 6" lift on my '86 & then got the 6" shocks & they don't have much compression left in them, but they do have plenty of downward travel. But I don't worry about ride quality in it so they work ok. The way I drive it the ride won't be smooth reguardless of the shock I use.
'71 C10 LWB 400SB/350TH '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
05-17-2007, 01:01 AM | #7 |
If you bought them for your 4 inch lift then they should be fine with th 6. I cant count how many times Ive swapped springs and the shocks are just fine. They usually have enough length in them for a +2 or -2 lift or lower.
05-18-2007, 12:09 AM | #8 |
Chevys Kick A$$
I have heard the same thing.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
