Old 05-15-2007, 01:10 PM   #1
killer71
killer71's Avatar
O.K. Boys let's see the gauges
I'm in the process of swapping to the Gen III 5.3L and will be going all electric. Give me some ideas on the conversion as it's hard to make my mind up trying to pickem out of a catalog---Killer!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 05-15-2007, 01:11 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: O.K. Boys let's see the gauges
I'm debating on doing the same swap and I think I would run the dakota digital gauges
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-15-2007, 01:15 PM   #3
killer71
killer71's Avatar
I like the dakotas but I want something with a little more character/identity!
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 01:17 PM   #4
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Not real good pics, but I think they're called Autometer classic chrome. Electric senders, but a more original look.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-15-2007, 02:08 PM   #5
fatboys69
fatboys69's Avatar
I have the Covan & Autometer set-up and they work great ( way more accurate than the stock gages )
fatboys69 is offline   Reply With Quote
Old 05-15-2007, 03:49 PM   #6
killer71
killer71's Avatar
Hey backyard let's see your steering wheel out of curiousity!
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 04:24 PM   #7
mvfd70
mvfd70's Avatar
Where did that steering wheel come from?
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 05-15-2007, 04:25 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm using the Autometer Phantom gauges in my truck. Here is a pic when I was test fitting the gauges
I initially had the mechanical speedo shown in this pic but I am swapping it out for the electric speedo. The only other mechanical guage is the oil pressure gauge. I'm very pleased with these gauges.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-15-2007, 04:33 PM   #9
killer71
killer71's Avatar
YJ--like the idea of the clock! Do they make a 3 3/8 in a fuel gauge?
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 04:37 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Thanks, had to have something for that location and the clock worked for me. Sure is loud when the truck is off but kind of cool to hear the clock ticking. I don't think anything other than the oil pressure gauge was available for that 3 3/8" spot.
Old 05-15-2007, 04:39 PM   #11
killer71
killer71's Avatar
Thanks for the info YJ...good lookin set up!
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 09:29 PM   #12
BACKYARD88
BACKYARD88's Avatar
It's a Grant. I think it's Mahogany. Kinda dirty right now.
-Mike Owen-
Old 05-15-2007, 09:39 PM   #13
1970bowtie
1970bowtie's Avatar
yes...but there not very common.
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 05-15-2007, 10:01 PM   #14
Hart_Rod
Hart_Rod's Avatar
Here's a picture of mine. It's got a 3 3/8 fuel gauge. DJRacer hooked me up with it (still brand new in the box, ) Putter did all the work, I supplied the $$$, .
Hart_Rod is offline   Reply With Quote
Old 05-15-2007, 10:22 PM   #15
Mudder
Mudder's Avatar
I was going to do mine behind the bezel but decided against it because of the double ring when done like that. So mine ended up like this. I have a 3 3/8 oil pressure gauge that is pro comp that is waiting to be used at an later date.
Mudder is offline   Reply With Quote
Old 05-15-2007, 10:24 PM   #16
Hart_Rod
Hart_Rod's Avatar
That looks very familiar.....!!!!
Old 05-15-2007, 10:37 PM   #17
killer71
killer71's Avatar
Hart Rod and Mudder; I would do you guys set up but I just can't find the 3 3/8 fuel gauge so I'm leaning towards Mike Nutts set up what do yall think?
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 10:41 PM   #18
Mudder
Mudder's Avatar
I think this would look great in the center hole. I believe it is the right size.
Old 05-15-2007, 10:43 PM   #19
killer71
killer71's Avatar
Hmmm! Who makes that clock gauge mudder?
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 10:49 PM   #20
Hart_Rod
Hart_Rod's Avatar
I'm thinking about doing a 3 hole gauge setup like Gringloco did for my CrewCab. I swapped them around a little though.
Old 05-15-2007, 10:52 PM   #21
Mudder
Mudder's Avatar
I can't find them there anyomre but they have changed teir site a bunch. here is the link if you wanna look for them.
http://www.mooneyesusa.com/
Old 05-15-2007, 10:59 PM   #22
killer71
killer71's Avatar
Hart Rod now those are sweet. 68ss and I have discussed going with that set up! What did it set you back and can those still be purchased?
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 11:15 PM   #23
killer71
killer71's Avatar
So what do you guys think of these?
R.I.P.
Killer 71
10/26/07
Old 05-15-2007, 11:18 PM   #24
sleepyboy
'69 Step
I went Dakota digital in blue with billit inserts on guage cluster and glove box..I like it alot.
sleepyboy is offline   Reply With Quote
Old 05-15-2007, 11:26 PM   #25
Hart_Rod
Hart_Rod's Avatar
Killer!!!!
