FS U-bolts for Dana44 - new
SOLD-----
Well, due to a miscommunication with the machine shop I now am the proud owner of a new custom bent set of U-bolts for a Dana44 front axle. They fit 2.75" tube Dana's. One is larger to fit over the diff. Includes washers and nuts, 5/8" stock. $45 shipped to your door... OBO FYI, corp10's have 3" tubes (which is what I told the guy when he made them) ![]()
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 05-18-2007 at 12:36 PM. |
Re: FS U-bolts for Dana44 - new
Interesteed pending pics thanks
hav'n fun be'n me ![]() |
Born Psycho
![]() Join Date: Feb 2001
some dana 44s are 3 inch also---found that out the hard way several years ago. i picked up a 44 out of a mid 70s 3/4 ton---just the housing with gears--and proceeded to rebuild it, new bearings, ball joints, tie rod ends, etc. put it under my 72 3/4 ton and THATS when i found out my u-bolts didn't fit and i'd also need new top plates. i called the dealer and at that time i could still buy new top plates---almost 200 bucks for plates
![]() another thing to remember, you can get almost any size/shape u-bolt from your local napa dealer. it's much cheaper than having them custom made---i found this out the hard way too. DAMN, i'm a dumb a$$
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA Last edited by jerry moss; 05-15-2007 at 10:21 PM. |
pics added, My NAPA dealer doesn't stock u-bolts so I had to go to our local machine shop that custom makes them....
These are for 2.75" not 3" tubes. I am going to try to reuse my plates since it only needs bent 1/8" on each side to fit. These are more than long enough for three leafs and probably four.... The second from the left opened up slightly but with a little effort it will fit in the plate...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 05-15-2007 at 11:35 PM. |
Born Psycho
my napa doesn't carry them in stock but can have them overnight, you just need a counterperson willing to take the time to look them up for you. the ones i had built several years ago cost me almost 100 bucks for four u-bolts.
ttt for you.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
These were bent from U-bolt stock so the threads were already done prior to bending... My shop runs about 40-50 for a set of four....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Sold !! thanks Mike
no problem PM sent for addy...
