72 C30 Trailer Queen
parts truck 68 GMC 1500 LWB BB AT AC in MN *SOLD*
7-6-07 update: Make a good offer on this truck, you know you want a big block!
More pics here: http://picasaweb.google.com/challsta...CC1500Bigblock I brought this truck home 2.5 years ago because I thought I might need some part of it... apparently I dont because I haven't touched it since!! 1968 C1500 Custom with 396 big block, TH400 automatic transmission, PS, PB and factory air conditioning. 3.54 Dana 44 rear end. Yes, a Dana 44 rear end with 3.54 gear ratio. I have the build sheet to prove it. Also note the 1968 only PS reservoir bracket. Previous owner's kid installed battery backwards and melted about every wire in the truck. They "fixed" it up with speaker wire. You should plan on new wiring throughout the truck. With that said, the truck runs and drives, the tranny shifts through all gears and the brakes work. AC compressor is missing, and quadrajet replaced with an Edelbrock carb. No exhaust on passenger side past the manifold. It will run long enought to drive on to your trailer. Body could be restored, better than most originals in this area of the country. I have a clean MN title in my name, ready to transfer. $1700 as is and where is. Thanks,
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 08-22-2007 at 01:34 PM. |
![]() Join Date: Sep 2006
Re: parts truck 68 GMC 1500 LWB BB AT AC in MN
No doubts about that rear. My dad had a factory 68 BB short bed with that rear in it as well. The power steering reservoir is interesting. I wonder if that's the same bracket they use on 69-72 big blocks with the auxilliary battery? Good luck with the sale.
70 Custom/10, 396, Muncie 4spd, SWB SOLD 72 Cheyenne K20, 350, Granny 4spd, LWB, daily driver 72 Cheyenne Super C20, 350, Turbo 400, LWB, parts truck for 4WD Cheyenne |
GEARHEAD
Theres a 69-70 in the salvage yard here that has the resevoir bolted right to the fender. A big block truck.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
anyone have a shot of the glove box or build sheet pic with 3.54 ratio dana 44 rear ..I'd like a pic view of it.
pm me for email addy if you want. Thanks ps: the ps bracket extension interests me if parting.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 05-17-2007 at 06:45 AM. |
Here are 2 pics: the build sheet and a close-up of the same buildsheet showing the axle number as a SP44 354.
I read that as a Spicer (Dana) 44 rear with a 3.54 gear ratio. I would be glad to sell that bracket... $1700 includes its rolling 4000 pound shipping container ![]()
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
Bump for ya,
They are out there... I pulled a Dana 44 3.54 posi from a 67 GMC (leaf type) in the local wrecking yard. It had a 305 under the hood. No it's Not for sale. |
This truck must get fantastic gas mileage...
I haven't had to fill it up for 2 years!
HI Chris,
Interesting extention adapter connected to the power steering fluid container. Respectfully
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
From what I understand, all 1968 big block trucks used this power steering reservoir bracket. Someone has mentioned 69-72 trucks with a big block and factory dual batteries also did?
I questioned if the 69-72 BB w/ dual batteries had that extension. Reason is I have a 72 factory brochure showing that extension, but I forget why. I'll have to find the brochure again and look. Looking at your engine pic, it seems there's plenty of room to mount the reservoir to the fender and still have the auxilliary battery there. Just curious. Anyway, TTT.
Did I mention that I could arrange delivery of this truck?
Have trailer, will travel!
chris any thing your needing and are you interested in trading for anything
common sense isn't so common anymore |
#13 | |
#14 | |
Thanks,
#15 |
lets get this one back to the top
#16 |
Is the power steering reservoir and lines for sale?
I'm also interested in 4 core radiator mounts upper and lower if/when you part it out....
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
#17 |
Sorry, but selling this truck whole at this point.
#18 |
Active Member
![]() Join Date: Nov 2002
Chris
If you decide to part it out I would be interested in the rear end.
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
#19 | |
For $1700, I will drop off the rear end and everything attached to it! Big block power would be mighty nice in that "new" Longhorn!
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 07-03-2007 at 12:55 PM. |
#20 |
Lots more pictures taken today:
#21 |
I dont want to have to part this...
I would consider seperating the engine/trans from the body.
#22 |
you said it runs enough to get on trailer, what would have to be done to drive it to brainerd, thanks ron
#23 |
Hope you can sell it whole, but if you do part it, I'm still interested in the power steering reservoir and bracket. Thanks
#24 | |
The smart and experienced side of me says pay me another $250 and I will deliver it to you on my trailer! (I could probably roll this weekend?) Less fun, but much safer and higher probability of an uneventful trip! Or borrow a trailer, dolly, tow bar or whatever... come down and haul it home yourself. You know you want to come check out the other truck treasures I have!! Thanks,
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 08-02-2007 at 06:31 PM. |
#25 |
Will keep you in mind if I end up parting. thanks
