05-15-2007, 07:03 PM | #1 |
rally wheel sizing?
Is the difference between the 15/8 and the 15/7 the offset, and then that affects the lip size, so the 15/8 then needs an inch larger beauty trim ring?
thanks |
05-15-2007, 07:08 PM | #2 |
The LuvShack Garage
Re: rally wheel sizing?
Humboldt? As in TN?
Trim rings are sometimes wider for wider rims, there is actually a 2" and a 3" version for the 15 x 8 73 up style 6 lug rally's alone. Good wuestion, and If ordered custom from Wheel Vintiques you can get anything you really want.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 05-15-2007 at 07:13 PM. |
05-15-2007, 07:11 PM | #3 |
15x8 are an inch wider than the 15x7's. The lip sizes are different and the trim rings are different. All four of mine are 15X8 with 88-98 beauty rings. They will look sweet once I get done painting them up.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
05-16-2007, 12:17 AM | #4 |
I just put the 3" beauty rings on my 15x8 rallys .... man !! made a big differnce in the looks
05-16-2007, 12:31 AM | #5 |
Yes it is in the offset, best way to solve that, use all shallow rings.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
05-16-2007, 09:34 AM | #6 |
F.A.S.T. president
Offset isn’t the only thing to take in consideration on the ring size. A 10 inch rim with 7 inches of offset has the same front lip as an 8 inch rim with 5 inches off offset or a 6 inch rim with 3 inches of offset. They would all use the same ring because the front rim depths are the same.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
