Old 05-15-2007, 07:33 PM   #1
solidaxel
solidaxel's Avatar
78 C10 A/C question
How do I tell if the fan switch is working without taking the dash apart?
My A/C wont fire up, fuse is good and power to the red, hot side of the fan reley. I jumpered across the low pressure switch at the accumelator still wont fire . when I jumper across the reley red to the yellow everything starts and cools but the reley gets very hot! What next?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-15-2007, 07:41 PM   #2
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: 78 C10 A/C question
Try completely bypassing the high blower relay and see if you can get a constant speed out of the blower motor. From under the hood you should be able to hear if the motor kicks on high or not. If it does, you have a bad relay or bad connections, which is what it sounds like to me. If it doesnt, you have a wiring issue and need a diagram.
xtreme80 is offline   Reply With Quote
