![]() Join Date: Dec 2001
Dashlight Question
Installed my dash today. I put new dash tach kit with new circuit board,wiring and all that good stuff. Here is my problem,the right turn signal indicator will not light and the fuel and oil pressure gauge lights will not light up. All the other guage lights work. I've swapped bulbs around and they are all good. Could I have a ground problem or maybe bad connection problem with the bulb holders to circuit board?
Thanks, Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
Re: Dashlight Question
It could be just a little pinch in the foil runs where it might be cracked. I would, if you have a multimeter or something to test resistance, check to make sure the foil runs are all intact going to the bulbs. You might not even be able to see the crack in it thats there.
1971 Chevy C-10-sold 1969 GMC 4x4-sold 1997 Chevy Z71 2003 Grand Prix |
TOTY 2006
![]() Join Date: Dec 1999
I had the the same type of problem with my new dash, only I had it on the shelf for about 4 years before I installed it. During that time, one of the foil in the printed circuit was cracked. Ordered a new printed circuit and was much moe careful handling it during install....
i 3rd the foil circuit
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
If you have any expirence with a soldering tool and find the crack, if any, you can run a bridge over the foil with another piece of foil if you have the old board or a piece of copper if you have some. You want to keep the same width for continuity, but as a last resort a piece of wire would work too. Make sure to clean the area and cover it with something like epoxy to keep moisture out and it should work fine
I'm starting to think this the problem too. Man, I hate taking that dash back out.
Thanks, guys
If the bulb holders are old, I would suspect them first. They will look just fine visually, but will not make contact with the bulb. It is easy to see if you have power up to the point on the circuit board where the bulb holder makes contact.
Tim |
#8 | |||
Union Electrician
I would personally check the grounding screws at the top coners of the dash, and if needed put a very thin small washer between the screw and the PCB. You of course will have to take the dash out to do this, but you can also check the PCB while it is out. I personally have never had any trouble with new repop PCB, and I have used several hundered of them, just my .02...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
![]() Join Date: May 2006
Also check the little metal tabs on the bottom of the light sockets, they might be corroded and it wouldn't hurt to bend the tabs up a little (towards the foil) so they'll make better contact.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 05-16-2007 at 08:34 AM. |
67-72 Addict!
I would bend the little tabs that hold the bulb inward to make them tight. Make sure they are not corroded. I also bend the ears on the socket to make it tight. Pretty common issue. You could always pull a known good socket out and switch it to the one not lighting to verify.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Thanks for all the info,I'll try to check things out this weekend.
