Old 05-15-2007, 10:34 PM   #1
RMATTZZ4
Axle swap...
I'll be swapping axles on my truck this weekend. Was wondering how hard this is? Anybody have any basic instructions, do and don'ts of doing this. I will be swapping in a set of 5 lug axles for the six lugs....
Thanks,,,,,Rob
RMATTZZ4 is offline   Reply With Quote
Old 05-16-2007, 09:54 PM   #2
71tahoe
71tahoe's Avatar
Re: Axle swap...
I pulled a diff carrier once (almost 20 years ago) and should be the same steps.
Axle length changed sometime in 1970. Newer trucks were about 1/2" longer each side. There is a post about using newer 5 lug in older axle housings. I saw it a few weeks ago but now can't find it.
Basically:
1. Make sure the truck is secure on jack stands. Double check (safety first).
2. Obviously wheels and drums have to come off. May have to knock out a plug in the backing plate to back off the brake shoes if there is a groove in the drums.
3. Drainpan under diff cover and drain fluid/take off.
4. Remove cross shaft bolt and cross shaft.
5. Push the axles inward for access to the c-clip. It may fall out if you rotate the axle or you may need a partner to help it out.
Hope I didn't forget anything.
Edit:
I did forget that you install in the reverse order. Should recommend replacing at least the seals and probably the bearings while you have the axles out.
71tahoe is offline   Reply With Quote
