Old 05-16-2007, 12:56 PM   #1
forsale
69 6 lug rotors conversion
What can I get these off of? Early Classic sells them for my front so I don't have to swap the rear.
What are they off of? Bearings seals and so on.
Thanks, Bill
forsale is offline   Reply With Quote
Old 05-16-2007, 01:08 PM   #2
69c10step
69c10step's Avatar
Re: 69 6 lug rotors conversion
ECE should have everything you need. This is the reply I received from them when I was asking about their conversion kits. BTW, I don't think they advertise the rear kit.
"our disc brake conversion comes with everything you'll need except wheel bearing grease and brake fluid. The booster is an option($229). Factory "slant outer" wheels will not work with disc brakes.
We do offer a 6 lug rear disc kit ($750) but we don't normally recommend rear discs on this style truck.
Thanks"
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 05-17-2007, 12:42 AM   #3
powell72
powell72's Avatar
I believe bearings and seals are just 71/72 stuff and the rotors are made specifically for that application, not a retrofit part from another vehicle.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
