hydra boost brakes
does anyone have a hydraboost brake system on their truck? if so i would like to know is it better than a regular vacuum setup. Also pics would be nice, thanks in advance.
#2 | |
Re: hydra boost brakes
![]() Join Date: May 2007
jkade can you give some details on you hydro trans plant
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
The hydro is off a early 90's 3500 chevy, I used the braket that was on it and drilled two holes and opened up the rod hole in the firewall and it bolted right up. I did turn the bracket upside down that holds the hydro. The mastercylinder is for a 67 vette and I had the p/s pump for hydro but you can use your stock pump. Oh yeah you have to cut the rod off and shorten it but I cut it off and cut my factory rod and welded the two together. I hope this helps.
Where can one find the hydraulic booster? I don't know that I have ever seen one on a vehicle. I like the idea though. Seems like it would be more reliable than vacuum
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
Check out www.hydratechbraking.com they sell bolt on kits for 67-72 chevy trucks and many other apps also. they are a little pricy but i talked to them and there kits are very well designed and mfg and come complete with everything needed. i have factory hydraboost on my '77 1 ton and i love them way better than vacuum assist
#9 | |
Mike
Mike Redpath |
